Can anybody help. I am using VCD gear GUI v0.02 too covert .dat files into .mpeg files. But I am having a problem trying to covert this one file it is saying that it can't find the .dat file that I have selected. But the .dat files plays fine in windows media player or any other player when I play the cd forn the cd-rom drive. This is the only VCD that I have had this problem with and I do not why. Please sombody help me.
Thread: .dta to .mpeg conversion
I hope this doesnt sound stupid, but u are actually authoring them properly, arent you?
You can just burn .dat files onto a CD, you have to do it properly, try using a program like Nero, or TSCV (nero is best for beginners)
Hope that helps if not, just reply back.Need a coach for anything? Try George Youngs Coaches here for the best service at the lowest prices: http://www.carlberry.co.uk/rfnshowo.asp?O=YOUNG
the promlem i am having is not authoring it is converting the dat file to mpegOriginally Posted by theoldinn
Sorry mate, completely mis read the question.
I have never used VCD gear. Try using TMPGEnc instead, maybe that will workNeed a coach for anything? Try George Youngs Coaches here for the best service at the lowest prices: http://www.carlberry.co.uk/rfnshowo.asp?O=YOUNG
I have just downloded a more upto date version of vdc gear and it seems to be working (at the moment)Originally Posted by chodges84
Here is an easy solution: Change the extension from .dat to .mpg
Works for me EVERY TIME!"I think I know exactly what I mean, when I say it's a Shpadoinkle day!"
Is there a timed channel changer for the comcast dta boxes?
By yoda313 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2011, 20:52 -
Hooking up my DVD/VCR to the DTA
By LadyAmethyst in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Oct 2010, 19:09 -
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / HDTVReplies: 5Last Post: 20th Oct 2009, 16:12 -
wots best method to split MKV - change DTA to MP3 then remux..?
By snadge in forum Video ConversionReplies: 1Last Post: 3rd Jul 2009, 13:33 -
Can Blu-Ray DVD be used for Dta storage ?
By orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2009, 21:01
