Is there someone who can help with how I make a Sony CX-995V from NTSC to PAL, or make it region free ?
Thread: NTSC to PAL ? Sony CX-995V
Many players simply cannot be region hacked....especially big names like Sony.Originally Posted by LundJepsen
did you recently buy it, in Denmark?
If so, and I am guessing you are trying to play commercial dvd's in ntsc that are region 1, take it back and get one that cann be hacked , like a Philips.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
Also, do not confuse regions and formats. Formats are technical specifications for video display. Regions are arbitrary groupings of countries designed to promote profiteering amongst movie studios. Making a player region free does not, alter it's ability to play different formats. If a player is NTSC only, adding the ability to play region 2 or 4 does not mean it will also play PAL discs. In fact, both Region 2 and Region 4 have PAL and NTSC releases (although R4 rarely has both of the same disc).
Most PAL players are multi-format by design, so you will rarely have an issue playing NTSC discs.
Hello again.
It must change from Region 1 to Region 2.
On the PCB there are 4 jupmer which can be set, is there anyone who know this player?
ps. It writes only "arial resticted disk" when I put a Region 2 disc in the player.
From what I can see, there is no soft mod for this player. If you want it region free then you have to have it hardware modified. The only recommended dealer for this change I could find is here : http://www.jvbdigital.nl/
Thanks guns1inger.
Thank you for answers.
Are there others who know Sony region modification??
comments requested please
Sony Hi8 (PAL) pass-through to Canon (NTSC) - will this work?
By frappefan in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 26th Dec 2010, 13:18 -
Convert SONY CAMCODER PAL to NTSC
By bkdomrep in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 31st Aug 2009, 11:25 -
will a NTSC sony FX1 work in australia were we use PAL?
By gogofilms in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 14th Aug 2009, 17:57 -
capturing on sony hdr-hc7 NTSC Tape / PAL Camera issue ?
By DKmickey in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 5th Feb 2009, 14:38 -
Sony KDL 26S3000 NTSC to Europe's PAL
By Konstan in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2008, 12:12
