Hello everyone
I was wondering if I install the mtp device driver, would I still need windows media player? The reason for this, is that I have a sansa view 8gb and I want to transfer music to it without having to use windows media player.
this is the driver
http://www.microsoft.com/downloads/d...displaylang=en
Thread: MTP Device driver
Some devices have an option for either MSC or MTP. Check that first. I thought XP included the MTP driver?
The file you linked to is just the specification, not a driver
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Hmmm, Yeah it does have the driver installed, but a pop up window does not appear when I connect it. The manual says I need to install wmp, I guess it works as a handler or something to that extent.
I was just wondering if it was possible to work this without having to install it.
any suggestions?
See if you can switch the device from MTP to MSC(UMS). I have several MP3 players, only one Sansa, most, including the Sansa e240 I own, do allow this in their settings. If not, try using google to search for an MTP compatible application.
yeah my sansa view does have this option. What I do is add the music to the music folder, but when I disconnect it, it starts to refresh and freezes... So the songs don't show up, but take up HD space on it.
#1 result from google, First FAQ at sansa.
01. Sansa player freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater.
If this article did not resolve your issue, please contact us at support@sansa.com.
http://www.google.com/search?q=Sansa...ient=firefox-a
http://www.sansa.com/support/sansa_view/faqsLinux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
well my sansa is up to date... But let me try that out, and let you know. Thanks for that
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum CapturingReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53 -
A tricky Driver for Capture Device Needed
By Digiliz in forum CapturingReplies: 9Last Post: 8th Jul 2008, 11:26 -
HP DVD Writer 300n SCSI CdRom Device Driver Issue
By link2009 in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2008, 16:50
