So I got my 5.1 ch system set up, I can tell it works because in windows sound config. I can click on any individual speaker and that speaker will play a sound separately.
When I play a game on my PC the 5.1 surround works, but when I play a blu-ray rip or blu-ray disc (or any other movie type), only the 2 main speakers work.
I use windows media player classic "hometheater" and VLC.
How can I make the surround work on movies too?
thanks
I would try ac3 filter. Install it and then configure it so it outputs to your 5.1 system and enable ac3 and dts decoding(it is enabled by default). Play with Media Player Classic Home Cinema.
Can I use my DVD Drive to Rip Blu-Ray Movies ?
By augustya in forum Blu-ray RippingReplies: 25Last Post: 2nd Mar 2012, 13:07 -
Play full blu-ray movies on ps-3 from hard drive
By jim49 in forum Software PlayingReplies: 2Last Post: 7th Apr 2010, 18:54 -
Trying to get 5.1 sound on blu ray rip
By mojo21 in forum Blu-ray RippingReplies: 0Last Post: 24th Feb 2010, 13:43 -
How do you play Blu-Ray movies at 60 frames per second?
By Obamargarine in forum Software PlayingReplies: 2Last Post: 26th Feb 2009, 22:19 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
Statistics
Newest guides
Latest tool updates
New media comments
