VideoHelp.com Forum
    Hi
    I use RipBot264 to create mkv files, that works fine and I can play them on my pc without any problem. But when I try to play them on my Tvix 6500 they play for a little while and then the tvix reboot. This happends on the exact same place in the mkv file. But this only occurs on the mkv files I create. I have tryed to create mkv file from m2ts file and a ts file. But the same thing occurs on both files. Can anyone give advice on how to find out what might be causing this, or recomend any other applications that create "fool proth" mkv files.
    I changed the subject. Please don't just use getting desparate as it says nothing about the problem.
    Does any mkv work fine on your tvix?
    What audio codec are you using?
    What h264 profile are you using?
    Hi Baldrick
    All the mkv file work except for the ones I create, the one I create almost all the time give me trouble on my Tvix. And it is always the same error, the Tvix reboots on the same place in a ceratain mkv file I have created. When I do my mkv files I use x.xcopy stream, and the High 4.0 bluray console profile.
  1. Issues with a subtitled mkv file on a tvix slim
    By ToxicFruit in forum Subtitle
    Last Post: 27th Sep 2011, 15:58
  2. Help with MKV files and Tvix 4130sh Media Player!
    By jcha7580 in forum Video Conversion
    Last Post: 26th Jan 2010, 18:11
  3. What do you think of TVIX HD M-6600N?
    By pwangdel in forum Media Center PC / MediaCenters
    Last Post: 8th Jan 2010, 06:34
  4. help tvix 6500 wont play true hd how do i convert
    By lodwales in forum Authoring (Blu-ray)
    Last Post: 21st Mar 2009, 07:45
  5. Dvico Tvix M-5100SH..? mkv? HD?
    By Nosferatuvn in forum Video Conversion
    Last Post: 12th Aug 2008, 18:29
