After clicking encode (avi to dvdmpeg2) I hear the DING! and get a finished text in the progress window but there is no file to be found. I've tried saving to 3 different locations, nothing. It's odd. What simple point am I missing here?
Results 1 to 26 of 26
Thread: No File After Encode
Please let us read the Process Information log about this conversion. You may access this log by clicking the blue "i" in the ffmpegX Progress window (after a conversion, or attempt).
/bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: No such file or directory
Sat Feb 14 21:43:44 EST 2009
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
The first line of the log seems to say it all: It can't find mpeg2enc. You need to (re)install it.
And don't forget: If it comes as a zipped (or otherwise compressed) file, you need to unzip it first, and then finish the install.
Perhaps that too, but the error is very clear about missing mpeg2enc, the third binary. Use the 'Install binaries' item in the ffmpegX menu to get the installer window back again. Or re-launch the app, which will do a check for the binaries and prompt the installer window if it finds something obviously wrong.Originally Posted by drummachick
Hi, I am having the same problem (encode - more often than not - but not always) does not encode, just 'Dings' straight away. I have been encoding from vob to mpeg 4 or DV - it has worked many times but frequently it doesn't and I don't know what determines whether it works or not. It seems to have stopped encoding anything now though! Any suggestions?? Thank you!
This is the info log:
Input #0, mpeg, from '/Users/Desktop/VTS_01_1.VOB':
Duration: 00:01:03.8, start: 0.188567, bitrate: 131151 kb/s
Stream #0.0: Audio: ac3, 48000 Hz, stereo, 256 kb/s
Stream #0.1: Video: mpeg2video, 720x480, 29.97 fps
Codec type mismatch for mapping #0.0 -> #0.0
Please see this previous post.Originally Posted by sallyg
I have the same problem which just started today. I've been using ffmpegX for several years now, but suddenly, when I try to convert an avi file to DVDmpeg2enc, then use Filters to add a subtitle srt file (VOB Subtitles, Text encoding: ISO-8859-1, font size 2, Pos 95), it instantly dings. When I try to preview the video, I get the following message with no mplayer video preview:
sh: -c: line 0: unexpected EOF while looking for matching `"
sh: -c: line 1: syntax error: unexpected end of file
This even happens when I try to convert a file that I previously successfully converted to a Video TS file.
The process information from ffmpegx Progress reads:
/bin/sh: -c: line 6: unexpected EOF while looking for matching `"'
/bin/sh: -c: line 7: syntax error: unexpected end of file
Any help would be greatly appreciated.
You would get this error if there is an apostrophe (') or quote symbol (") in the file name or one of its parent folder names, or in the volume/disk name. Change the name, and it should work again.Originally Posted by macgurl
Wow, thanks for the quick reply! You're right--I put the files in a folder that had an apostrophe (A Man's Story) and then none of the files worked. I'll give it a try and see if I can encode this time.
Yes, it worked! Another note to self: don't use apostrophes! Thank you for the quick and helpful reply.
You're welcome.
I am having the same problem... press "encode" then dings, but doesn't save. Here is what it says when I press the 'i' button:
Encoding started on Sun May 31 12:04:48 PDT 2009
MPlayer dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
Unknown option on the command line: -oac
sounds like it has something to do with the "Unknown option on the command line: -oac." I'm not very good with computers, just trying to get some of my camcorder footage to post on youtube. In this, can you please computer talk to me like a 2 year old, thanks!!!!
I would have expected a line like:Originally Posted by lauren
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
that is, "MEncoder" instead of "MPlayer".
Is it possible that you switched these two binaries in the installer window?
Please tell us which settings you used to get this error, so that we may try to replicate it on our side.Originally Posted by lauren
-oac is the "output audio codec" option
which will not be understood by a player, but is a needed parameter for an encoder. The "Unknown option" would happen if your mencoder binary was switched for mplayer.
Go to the menu bar at the top of the screen, where it says "ffmpegX". From the pull down menu, select "Install binaries" to bring the installer window back. Set the checkboxes. Locate the binaries again, in proper order. Install.
Try encoding again.
Awesome, thanks for replying Case. So I reinstalled MEncoder (I think that was the one at least), then got it to save to a .avi. Then I opened the .avi and played it in quicktime and it was all black, and the video lasted a couple of minutes. When I clicked on the 'i' it had a lot of stuff to say:
Encoding started on Sun May 31 15:21:57 PDT 2009
AltiVec found
CPU: PowerPC
libdvdread: Couldn't find device name.
Reading disc structure, please wait...
*** Zero check failed in ifo_read.c:324
for vmgi_mat->zero_3 = 0x00000000010000000000000000000000000000
There are 2 titles on this DVD.
There are 5 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0x86d7800
MPEG-PS file format detected.
VIDEO: MPEG2 720x480 (aspect 2) 29.970 fps 9400.0 kbps (1175.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening audio decoder: [liba52] AC3 decoding with liba52
Using AltiVec optimized IMDCT transform
AC3: 2.0 (stereo) 48000 Hz 256.0 kbit/s
AUDIO: 48000 Hz, 2 ch, s16be, 256.0 kbit/16.67% (ratio: 32000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
Checking for AltiVec resampler : 0x00000002, 2
Using AltiVec optimized resampler
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
The selected video_out device is incompatible with this codec.
Also try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Forcing output fourcc to 58564944 [XVID]
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/0ch/s8...
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/2ch/s16be...
VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: libavcodec (640x352 fourcc=58564944 [XVID])
Writing AVI header...
1 duplicate frame(s)!
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
Skipping frame!
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 1065.187 kbit/s (133148 B/s) size: 33018296 bytes 247.981 secs 7439 frames
Audio stream: 128.000 kbit/s (16000 B/s) size: 3975936 bytes 248.496 secs
Encoding completed on Sun May 31 15:26:08 PDT 2009
any ideas??
That would be the mencoder DivX preset (AVI DivX, mencoder mpeg4).Originally Posted by lauren
QuickTime may need some help reading this format. Please install Perian to let QuickTime read many more media formats and codecs.Originally Posted by lauren
0:04:08 (248 secs), according to the log.Originally Posted by lauren
It seems you are converting from a VIDEO_TS folder? This DVD had two titles. Perhaps the default Title 1 is 0:04:08 and isn't the one you intended to convert. Perhaps Title 2 is the main feature you were trying to make into AVI. You may change the DVD title number to convert in the bottom-right section of the Video tab.Originally Posted by lauren
This part of the log is typical of a successful conversion: a summary of the output video and audio.Originally Posted by lauren
that totally worked! The only thing I may want to change is the resolution, wish it was more crispy-clear. Is there any way to get a higher resolution on the .avi file?
I' having a similar problem. I'm converting MOD files to MPG. I hear the "zing" but find no file. I also don't have audio when I click on the "preview" tab in ffmepgX 0.0.9. Here's the "info" message I receive after encoding:
Encoding started on Mon Jun 1 11:37:52 PDT 2009
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mpeg, from '/Volumes/EVERIO_HDD/SD_VIDEO/PRG001/MOV001.MOD':
Duration: 00:00:08.3, start: 0.513844, bitrate: 9339 kb/s
Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 8900 kb/s
Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 384 kb/s
Incorrect frame rate
Like another person above, I'm almost clueless about video files, so please respond in simple terms. What am I doing wrong? Any help would be appreciated. Thanks!
You're welcome.Originally Posted by lauren
Only some of the crispy-clear is lost in the output resolution. There is also a bit of quality loss every time you convert video.Originally Posted by lauren
In the video tab, under Video parameters is the output Video size. Width and height of video works a bit different for DVD versus AVI (pixel aspect ratio), so simply copying numbers to match the source file (720 x 480) would give an unwanted stretched picture.Originally Posted by lauren
You may change those target video size parameters to 848 x 480 (upscaling with original height), or 720 x 400 (original width). Most people seem to prefer the latter over the first, as the first will look a bit soft because of the upscaling, and the file would be 40% bigger for being just 20% better in resolution.
Case, you've been huge
. I'm going to try both, the 848 X 480, and the 720 X 400, see which I like best. You'll have to check out some of my vids when I finally get them posted, maybe in a week or something, http://www.youtube.com/sunnysaunter
The "no file after encode" may be the same, but everything else is different.Originally Posted by BePeace
It already is MPG. Just change the suffix.Originally Posted by BePeace
That may be a bug or limitation in mplayer.Originally Posted by BePeace
See? Source video is MPEG-2, audio is AC3, just like with .MPG files.Originally Posted by BePeace
Check the target framerate in the Video tab. ffmpegX may have misinterpreted the source file and defaulted to a weird number (0 or 1000 or ...). If it is "29.97" then the error message is mistaken, as 29.97 fps is a good number for mpeg-2 framerate.Originally Posted by BePeace
The encoding with ffmpegX v0.0.9y (on Macc OSX 10.5.7) systematically ends very quickly with a ZERO Kb file and no information abot error.
What's weong ?
I tried with different files and file formats (mpg of FLV) to convert into any other file formats. No one works !!
Thank you for your support !
Pablo
The log (with possible errors) is accessible by clicking the blue "i" in the ffmpegX Progress window. Please post that content here for review.
I am having a similar problem. here is my file progress screen:
Encoding started on Mon Jul 13 08:54:58 CDT 2009
/bin/sh: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
movtoy4m
Thanks in advance
Cannot encode my avisynth file
By V-Spatial in forum Newbie / General discussionsReplies: 6Last Post: 25th Feb 2010, 14:13 -
No file showing up after encode
By chack311 in forum ffmpegX general discussionReplies: 1Last Post: 12th Dec 2008, 14:04 -
Re-encode video file
By KoRatta in forum Video ConversionReplies: 5Last Post: 10th Jul 2008, 09:36 -
won't encode full file, and will only do certain file formats
By GregDz in forum ffmpegX general discussionReplies: 0Last Post: 21st Jun 2008, 21:27 -
all I want to do is encode an avi file
By moopsimoo in forum Newbie / General discussionsReplies: 8Last Post: 18th Jan 2008, 14:56
