If there are mencoder experts out there, I would like to ask if you know a way to blend every two frames into one frame throughout a video. I don't see an option like that in the mencoder options, but maybe there is some way to do it. To be more clear, I am talking about blending the motion of two physical frames into one, as if they were both half transparent and visible at the same time. What I want to do is maintain a strobe effect of a game capture while cutting the framerate in half. I can cut the framerate in half fine, but that's about it. I could do it manually frame by frame with an image editor, but that's pretty ridiculous, not feasible.
Results 1 to 1 of 1
Thread: frame blending with mencoder
mencoder + H.264 + XBox 360 - container and codec frame rate differs
By ali.khalil in forum LinuxReplies: 0Last Post: 24th Sep 2009, 09:31 -
VirtualDub Filter Blending
By sambat in forum EditingReplies: 4Last Post: 6th Sep 2009, 14:07 -
Sporadic frame blending in PAL DVD of Soviet-era film
By chipsndukes in forum RestorationReplies: 3Last Post: 19th Apr 2009, 22:42 -
Image Blending
By keithnut in forum EditingReplies: 4Last Post: 15th Jun 2008, 11:36 -
MEncoder skipping frame with audio conversion
By Towin in forum Video ConversionReplies: 2Last Post: 24th Mar 2008, 11:08
