[quote="usually_quiet"][quote="Snaque"]The "grey" I ordered makes these claims (If this makes sense)...In theory, I "should" be good with cable....Originally Posted by usually_quiet
Recording and playback:
Records in PAL or NTSC on DVD-R DVD-+R, DVD-RW, DVD+RW, and DVD-RAM - Regular or Dual Layer discs
The DVD made on this model will be all regions you can play it on any DVD player in the World, even on PAL DVD players. You can send the DVD made on this recorder to a PAL or NTSC country.
Records PAL to PAL
Records NTSC to NTSC
Plays NTSC on NTSC TV or Multi-System TV
Records in "ALL" regions format for worldwide compatibility
250 GB Hard Disk Drive (up to 711 hrs)
54MHz/10-bit video DAC
96kHz/24-bit audio DAC
Progressive Scan for PAL
Selectable interlaced/progressive-scan video (playback only)
de-interlacer with 3-2 pull down processing
Built-in PAL/Secam DK, BG, I, DK TV tuners
Results 31 to 33 of 33
"Does that make you nervous?"(pointing pistol)..."Guns don't make me nervous, they have their uses...It's IDIOTS, like you, with Guns that make me nervous" - Chas. Bronson from "Death Wish" film series
The specs for that model list "Built-in PAL/Secam DK, BG, I, DK TV tuners", so you are correct about there being a tuner issue.
The gray-market DVD recorder will have to be used exclusively with line inputs originating from either a VCR or the cable box, which will act as an external tuners. At worst, you may need to buy some switches to allow more inputs to the DVD recorder and/or splitters to provide more outputs from the VCR or cable box, depending on what your equipment has in the way of line-in/line out connections.
Affirmative, Bro'...At this point it is a waiting game for both units to arrive back in my hot lil' hands from distant locationsOriginally Posted by usually_quiet
...Will update as the action happens....
Zero luck with creating Region Free discs
By THRobinson in forum DVD RippingReplies: 16Last Post: 3rd Feb 2011, 15:43 -
Creating High Def (AVCHD) Discs on a Mac?
By ehmjay in forum MacReplies: 0Last Post: 14th Nov 2009, 23:11 -
Anyone here use nlite for creating custom xp install discs?
By freebird73717 in forum ComputerReplies: 5Last Post: 9th Mar 2009, 11:01 -
What is the best specs. for creating blu-ray discs in encore cs3
By jbandy1 in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jan 2009, 16:09 -
Creating DVD Discs
By ngoodfella in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 19:13
Statistics
Newest guides
Latest tool updates
New media comments
