VideoHelp.com Forum
Results 1 to 9 of 9
    I am on an Intel Core 2 Duo iMac running OS X 10.5.6.
    I installed ffmpegX according to the instruction at http://ffmpegx.com/download.html
    Everything went pretty smooth. I verified that the installer copied the files into /Library/Application Support/ffmpegX directory with the owner/group settings of root:admin and permissions of 755 (-rwxr-xr-x, except that mpeg2inc has a permission set of -rwxr-xr-x@)
    ffmpegX launches just fine and I can specify settings, etc. However, when I try to convert a QuickTime .mov file to .flv, I get the following encode details and 0K files:
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    Thu Feb 12 10:58:57 MST 2009
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/sysadm01/Public/Jobs/Sites/westpress-joomla/assets/PrintingIndustriesofAmerica/Transparency.mov':
    Duration: 00:04:07.6, start: 0.000000, bitrate: 925 kb/s
    Stream #0.0(eng): Audio: adpcm_ima_qt, 48000 Hz, stereo
    Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 480x270
    Codec type mismatch for mapping #0.0 -> #0.0
    Can someone please help me troubleshoot this?
  2. Explorer Case's Avatar
    In your .mov file the audio stream is listed before the video stream. This is reverse from how ffmpeg handles conversion by default. For other types of conversions, I would recommend the "Invert mapping" setting in the Audio tab, but for conversions to FLV this setting would introduce a stuttering issue with Adobe Flash Player (the webbrowser plug-in) that you wouldn't want.
    You can invert the streams manually using QuickTime Pro before conversion as a work-around, so that ffmpegX wouldn't need inverted stream mapping.
    Edit: link updated
    Freakn brilliant! Thank you
    This issue arises so frequently that perhaps it should be made a sticky. Ditto for the "where is progress.app" issue, perhaps.
    Just a thought. It would save a lot of Case's time.
    I tried that and now I get this error:
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/ajohnson/Desktop/toyota project5a.mov':
    Duration: 00:03:42.5, start: 0.000000, bitrate: 167260 kb/s
    Stream #0.0(eng), 29.97 fps(r): Video: Uncompressed 8-bit 4:2:2, 720x480
    Stream #0.1(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Mon Apr 6 14:22:08 CDT 2009
    Output #0, flv, to '/Users/ajohnson/Desktop/toyota project5a.mov.ff.flv':
    Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 400 kb/s
    Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    Unsupported codec (id=0) for input stream #0.0
    I have the files uncompressed. Do I need to have them compressed for this to work?
  6. Explorer Case's Avatar
    Originally Posted by deecro
    Input #0, from 'foo.mov':
    The codec that is used to describe "Uncompressed 8-bit 4:2:2" video isn't understood by ffmpeg. Try setting ffmpegX to 'Decode with QuickTime' (in the Options tab), so that ffmpegX can try to hook into the QuickTime architecture for reading the source file. I think that should work if "Uncompressed 8-bit 4:2:2" is available on that machine (part of Final Cut?).
    Alternatively, try working from a compressed file.
    Yeah, it was part of final cut. I tried decode with QT to no avail. I then tried the animation codec on output from FCP and it seems to work that way as long as I manually invert the mapping (using DV makes my text go to crap.) Took all day, but I finally managed to make it work!
    Hi:
    I am having the same problem. Just downloaded FFMpegx today and am attempting to encode a QT movie into flash. I've tried setting to "Decode with Quicktime" but to no avail. When it is complete MPEG Streamclip opens with the error message "File open error: the file is too short". Any clue as how to tackle this? FYI: I currently don't have FCP on my comp therefore I cannot convert to an animation codec as the previous poster has.......
    Tue Feb 2 16:21:39 PST 2010
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/garynueman/Desktop/Films 4 website/line/Sprint_Dreams Cut.mov':
    Duration: 00:00:51.7, start: 0.000000, bitrate: 619 kb/s
    Stream #0.0(eng): Audio: adpcm_ima_qt, 22050 Hz, mono
    Stream #0.1(eng), 14.98 fps(r): Video: h264, yuv420p, 480x360
  9. Explorer Case's Avatar
    Please see the second post in this thread.
  1. [FFmpeg] Problems encoding a MOV
    By Klagar in forum Video Conversion
    Last Post: 29th Apr 2011, 11:18
  2. Encoding problems
    By El Barto619 in forum Newbie / General discussions
    Last Post: 10th Jun 2009, 22:32
  3. Problems with Vimeo Encoding
    By Xenon77 in forum Video Streaming
    Last Post: 28th Apr 2009, 12:04
  4. Problems encoding!
    By villa99 in forum ffmpegX general discussion
    Last Post: 25th Mar 2009, 12:50
  5. DivX Encoding Problems
    By ftshark in forum DVD Ripping
    Last Post: 7th Mar 2008, 11:30
