Hi after finally finding the password to my daughters dell diminsion e521 i need to remove the system password login screen that comes up before the regular user login. I have the password so is there a way to totally remove this from showing up. In order to put a blank password whats the way of doing that.
Results 1 to 14 of 14
XP or Vista?
The answer will be found at www.annoyances.org for sureWant my help? Ask here! (not via PM!)
Are you talking about the BIOS or the user password?
If BIOS then you have to remove the motherboard battery or use jumpers,sometimes you can reset the password with eight spaces(spacebar).
If user look here:
http://pcsupport.about.com/od/windowsvista/ht/rvistapassword.htm -
The sytem has a password before you get to the user login that asks for a password. The system password is the one i want to get rid of.
Search the net for "control userpasswords2" and youll find the answer.
The OP refers to a BIOS password. That's not Windows.
Enter the password, then hit whatever key allows you to enter the BIOS setup. Tab to the PASSWORDS section, then follow the BIOS directions (should be shown on the screen) on clearing the password.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
That is the bios password , reboot and keep hitting DEL key until it goes into bios there you can blank the password.
http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/techov.htm#wp1058256 (motherboard bios jumper location is 21)
Remove system battery and power lead ... leave it in this state for 30 minutes to alow all power in motherboard to deplete.
Or
(where password fails to clear or access to cdrom was disabled)
Take drive to another system
Set this system to boot from cdrom only, disable hd boot feature.
Grab a copy of the ultimate boot cd and run ata password tool. -
Removing motherboard battery will erase your bios and if you have special setups like Time & Date, Raid or any setting in bios that was customized will be lost and you would be in trouble. Make sure you understand the setups.
Actually, removing the battery will reset your BIOS to default and remove any custom setups, same as using the jumper. But that's probably what you meant. Erasing the BIOS, if you could even do it, would necessitate replacing the BIOS chip.
He HAS the password. He wants to REMOVE having to enter it each time. There is NO need to "reset" the BIOS settings.
Just go into the BIOS SETUP and clear the current password to <blank>. It would be nice if the OP would provide feedback and give us his status on this problem.ICBM target coordinates:
Yes I meant bios will be defaulted. Thanks for correcting me. In these days lots of motherboards even if you crash during flashing the bios it has auto recover like ASUS or 2nd bios chip like Gigabyte. One never knows computer may have a 2nd drive or some sort of memory, boot priority etc that may not boot on default bios setting and resetting it for average user is not a good idea unless they know how to setup bios settings. We have to thank God those days that we had to setup IRQ's and memory allocation has passed.
using virtualdub filter to remove text on screen
By snafubaby in forum CapturingReplies: 2Last Post: 11th Jan 2009, 00:09 -
XP login screen
By rubberman in forum ComputerReplies: 6Last Post: 10th Aug 2008, 11:00 -
login not keeping password....
By rubberman in forum ComputerReplies: 3Last Post: 25th Jul 2008, 14:13 -
.AVI File Displays Time on Screen - How to Remove?
By Blacklight in forum Software PlayingReplies: 6Last Post: 15th Jul 2008, 10:30 -
Software tools to remove deinterlacing lines from video screen grabs?
By nzo in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2007, 22:48
