VideoHelp.com Forum
    Hi,
    I tried to use the region code hack posted by JJFF, June 29, 2008, I found the RH3xx.iso and downloaded it. It's a zipped file. How to burn it as an image to a CD? It's not possible. When I unzip the iso-file I get a file called RMTM0000 which contains a file called Scarlet. What do I have to burn? And what is meant by "must be burnt as an image", do I have to transfer the file to another file extension for images, like jpg or so? Please help me, I have no idea and little computer knowlege only , but it's the only way to watch my US and australian DVDs.
  2. Member hech54's Avatar
    Try by using ImgBurn to burn the .ISO Image to a CD.
    Thanks, I'll try. So, if I understand you right, it's not necessary to unzip the iso-file before burning?
    I am troubled by your references to "unzipping" the file. If the names ends in .zip, then yes, you must unzip it prior to burning If the name ends in .ISO, then you are NOT unzipping it. You are using something to extract the contents from the ISO and you don't want to do that. You need to burn an ISO file as it is without any extraction. Maybe your unzip program, whatever that is, has the ability to extract the contents from an ISO file. If so, again, do NOT do this. You need to burn an ISO as it is without any changes by you.
    I'm sorry to trouble you, but the file is called RH3xx.iso and the type is shown as winzip file. So around the symbol for the file is a bench vice that means it is zipped. I got a program called Winzip to unzip such files. That's why i thought it should be unzipped first. But I'll try to burn the .iso now as it is. Thanks for your help.
    No, actually what it means is that Windows has associated WinZip with this program, NOT that it is an actual zip file (it may or may not be). I don't use WinZip. Probably WinZip simply knows how to extract information from ISO format, hence the association. Don't unzip it, burn it as it is and probably that will solve your problem.
    Thanks a lot for your advice and explanation. I burnt the .iso now and have to see the, if it will solve my problem.
  1. Euroline DVD100 DVD Player Region all region code/hack?
    By mjgjhb in forum Newbie / General discussions
    Last Post: 21st Jul 2011, 09:26
  2. Region code hack for BD630?
    By leocosta173 in forum DVD & Blu-ray Players
    Last Post: 5th Jun 2011, 23:34
  3. Region hack code
    By Shopgirl in forum DVD & Blu-ray Players
    Last Post: 25th Dec 2010, 18:39
  4. Region code hack
    By xandru66 in forum DVD & Blu-ray Recorders
    Last Post: 19th Aug 2009, 07:11
  5. region code hack
    By elpini in forum Newbie / General discussions
    Last Post: 20th Feb 2009, 19:02
