VideoHelp.com Forum
Results 1 to 9 of 9
    I'm looking for a fully equivalent to media player classic in linux. i need a player with the option (i think it's called letterboxing) to display subtitles over the black borders of the movie, not only within the height of the movie. also i need it to auto-load subtitles with the same name of the movie. I have a tv i use with tv-out, so i also need the option to display at fullscreen on secondary display; i also a have a remote infrared control, so i need it to support commands like VK_SPACE (for pausing) to be able to use the remote control; and finally i also need the option to normalize volume.
    is there a video player in linux wich does these things?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You could try VLC. I don't know if it will do what you want, but it's very versatile and has a lot of options. But someone here may have a more specific recommendation.
  3. or smplayer
    but it's to try , maybe don't have all options you need
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
    neither of them have these options
    Maybe GOM ?
    isn't that for windows? in their web page says
    System Requirements
    Microsoft Windows 98SE, Me, 2000, XP, 2003 or Vista
    http://www.gomlab.com/eng/GMP_download.html
  7. Get Slack disturbed1's Avatar
    Mplayer and VLC do have those options. Take a look at the configuration. I know for a fact VLC will display on a secondary screen, map shorcuts to whatever you want, and place subtitles where you want. Mplayer is more capable than VLC, so I'd assume it can do all of the above, plus more.
    Try reading the man pages, help docs, wiki sites, or home page of each project.
    Go here http://www.videolan.org/vlc/features.html
    check out Interfaces, Infrared? Check
    You can force the subtitle position - CTRL-S (for preferences) enable advanced, expand Video, check out the options for subtitles.
    Nothing special needs to be done to auto load subtitle files, as long as they have the same name as the movie. For example, dumbmovie.avi dumbmovie.srt <- this will auto load. IThinkIAMSPECAIL.avi ithinkiamspecial.srt <- will not auto load
    If you use Framebuffer, OpenGL(GLX), X11, or XVideo as the video renderer you can specify the display number also from preferences.
    Also in the preferences, Audio, Filters, check normalize.
    Honestly, did you even take a look at the options for VLC?
    http://wiki.videolan.org/Main_Page
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    yes, and i even asked at the forums but it can't display subtitles over the black borders of the movies, it can only add more black borders and display subs over these black borders you added
    and isn't smplayer a gui for mplayer?
  9. Get Slack disturbed1's Avatar
    That's strange. On my TV, the subs are overlayed on top of the movie, which I can position up or down. Perhaps it has to do with having a 16:9 TV, component out put, and watching 16:9 content? I can recall a few years ago when subs would show up below the movie on my SD TV when watching 16:9 content.
    Yes. Mplayer also has it's own gui, it's just smplayer looks/works nicer to some people. Besides VLC and Mplayer, there is also the xine engine. Kaffeine is a nice GUI for xine. But.... not I'm claiming xine supports anything you want to do, as I haven't attempted to use it for TV out viewing. Since you can't get VLC's options to work, perhaps Xine has something for you
    Taking a quick peek at the xine subtitle options, it does have vertical offset, but so does VLC
  1. Portable DVD Player vs Portable Video Player
    By DJboutit in forum Newbie / General discussions
    Last Post: 19th Apr 2012, 15:30
  2. Looking for a Good Video Player Or DVD Player
    By DJboutit in forum Portable Video
    Last Post: 6th Jun 2009, 21:57
  3. Replies: 3
    Last Post: 6th Dec 2007, 23:24
  4. Replies: 8
    Last Post: 17th Oct 2007, 06:05
  5. how do I flip an AVI video in windows media player or media player classi
    By mdavenport in forum Newbie / General discussions
    Last Post: 5th Jul 2007, 23:18
