VideoHelp.com Forum
    Hello, i'm looking for an equivalent to winavi in linux. in need a program with GUI, capable of converting any format (.wmv, .mov, .mkv, .asf, .avi, .rmvb, etc) to non-standart vcd (mpeg1) and dvd. BUT the most important thing, in winavi it gives me the option to select estimated file size by automatically doing changes in bitrate, etc. and most of the times it works very accurately. i want something in linux capable of doing that.
    and i also need the options to merge varios files, paste subtitles (appearing over the black borders of a movie), select pal/ntsc, select wich audio and wich subtitle in mkv's and have a queue list for converting varios videos one after other.
    is there a program that does all this?
    if not, is there any way to use winavi in linux?
  2. Get Slack disturbed1's Avatar
    Winavi works in wine.
    On the left click tools, this will open the tools section. In the tools section there is a link for Linux Video Tools, have a look see http://www.videohelp.com/tools/secti...ux-video-tools
    Any of the ffmpeg and mencoder gui applications will do what you want, as will Tovid (Tovidgui, Todiscgui). A couple of others to to check out -
    DeVeDe and Winff
    Also try http://www.google.com/search?hl=en&f...=linux+ffmpeg+
    http://www.google.com/search?hl=en&q...ui&btnG=Search
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  3. Member ricardouk's Avatar
    Autox264, winff and avidemux are good and cross platform but dont think they support all that
    I love it when a plan comes together!
    Ricardo Santos
    i tried mencoder gui's (the best i found was devede), but the thing i'm looking for is for me to select an estimated file size between a posible range and let the player auto adjust the video settings for the output file size to be that, and deve can't do that, when i want to convert a large video to vcd and i put it to 700mb (cd), it says that it will use, for example, 160% of the disk (so it doesnt fit on a cd), but doesn't autoadjust the output settings for the file to fit in a 700mb cd
    in avidemux i neither didn't saw something like that
    i'll try the ffmpeg gui's and tovid
    BTW how did you get winavi to run under wine? i tried but it only shows the starting logo and then nothing happens, and under crossover it says that there's a problem with a .dll (i think it wasd major.dll) and nothing more happens
    EDIT: tried winff and tovid but none of them had the option to set a size for the output file
  5. Get Slack disturbed1's Avatar
    Take a look at the programs again. I use Tovid almost daily, it's there. DeVeDe has it as well. Here's a screen shot for you.
    Winavi on wine - install wine, setup wine, install xvid, install Winavi, run Winavi.
  1. Replies: 1
    Last Post: 10th Dec 2011, 02:06
  2. Replies: 0
    Last Post: 23rd Aug 2011, 15:26
  3. MPEG II Video Quality drops using Any Video Converter...
    By Spoilerone in forum Video Conversion
    Last Post: 10th Feb 2011, 11:30
  4. Replies: 5
    Last Post: 25th Feb 2010, 15:33
  5. Replies: 1
    Last Post: 27th May 2009, 07:52
