I have a USB capture card that I'd like to use to record some game play, but there is a slight lag between button presses and actually seeing the action on the monitor. So I'm wondering what a good (and cheap) way would be to hook up the Gamecube to the capture card (using S-Video) and to a TV (I don't care what connection is used for that). That way I can play on the TV while I record using the capture card.
I understand that using a 'Y' S-Video splitter is not an optimal solution and will result in signal loss. I was wondering if something like this would suffer from the same problem? (With me hooking up the S-Video output to the capture card and the composite output to the TV?) Or alternatively are there any other cheap (<$30 USD) ways to go about this?
Results 1 to 1 of 1
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum CapturingReplies: 85Last Post: 21st Mar 2012, 12:27 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum CapturingReplies: 3Last Post: 1st Oct 2007, 10:51 -
Need Help: Need a Video Capture card with FM (Time Shifing).
By monkyman in forum CapturingReplies: 1Last Post: 18th Sep 2007, 10:12 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum CapturingReplies: 1Last Post: 6th May 2007, 17:15
