    I got this DVD from NetFlix, but I guess it's in NTSC format and my DVDRom is for PAL. The DVD worked well on my friends laptop 'cause it was purchased here in the USA. My laptop is not that old. It's a HP DV series bought in 2007.
    How do I run the DVD on my laptop? Also how to check if the DVD is PAL or NTSC?
    Thanks in advance!
  2. Member Noahtuck's Avatar
    There is no such thing.
    PC's & dvd-rom drives are not format specific when it comes to PAL or NTSC.
    Now the drive maybe getting region locked because it has been changed more than 5 times is another story.
    You could check it with DVD Decrypter to get the frame rate and/or resolution to see if it is PAL or NTSC and also to see what region the disc is.
    There are programs in the "TOOLS" section that will allow you to play other "Region" disc's or you can search for a region hacked firmware to reflash your drive and never worry about region lockouts again.
    Originally a member since 2001, LONG LIVE TARAN's!!!
  3. Always Watching guns1inger's Avatar
    Try DVD43 or AnyDVD to see if that overcomes the region restrictions, otherwise it is time for a firmware upgrade if possible to remove said restrictions for good.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. Replies: 2
    Last Post: 17th Jan 2009, 15:36
  2. ntsc tapes pass through pal camcorder into mac for ntsc playing?
    By tozier9 in forum Newbie / General discussions
    Last Post: 7th Dec 2008, 18:19
  3. playing pal svcd on ntsc tv with pal capable dvd player
    By Veron in forum Newbie / General discussions
    Last Post: 8th Jul 2003, 16:07
  4. Playing PAL vcds on NTSC
    By JGDragov in forum DVD & Blu-ray Players
    Last Post: 3rd Oct 2001, 07:25
  5. playing ntsc on pal tv
    By oxide in forum DVD & Blu-ray Players
    Last Post: 10th Jul 2001, 10:31
About   Advertise   Forum   RSS Feeds   Statistics   Tools
