I have several .mkv files which play on my PC with no issues. When I try to play them on the WDTV it says it does not support vibos codecs. Can anyone help?
Results 1 to 9 of 9
What is "vibos"? Do you mean "vorbis"?Originally Posted by stevencg
Open the file in mediainfo to identify the codecs being used. If it's not supported by your player, convert it to a format that is supported (e.g if you really meant vorbis audio, then convert it to mp3 for example, then use mkvmergegui to re-assemble the new mkv with mp3 and without the old vorbis track)
Sorry you are right i meant to say vorbis. I was hoping to avoid converting files. I also have super C, will that work? The files doesnt have to remain a .MKV.
super should be able to do it, if not you can use lamexp
1) Use mkvextractgui to extract the audio track
2) Convert the audio track with some program (e.g. lamexp, super, etc..)
3) Open the original .mkv in mkvmergegui, add the converted audio track, uncheckmark the old vorbis track and re-mux a new mkv
Sometimes it will not be in sync: if there was a media delay in the original .mkv, this is not preserved when demuxing with mkvextract. You could determine the delay with eac3to and enter that number when re-muxing the new mkv
Cheers
You could open the MKV file with AviDemux, and convert the audio to something the WDTV can handle.
Funny, I saw this message soon after it was posted but didn't know what vibos was. So I didn't reply!
Both are converters but it should be easier using avidemux, just open the mkv, under video choose copy, under audio change audio codec to like mp3, under format choose mkv and convert.
Thanks for the help guys, i will let you know how things go!
Just ran across the same problem, strange it can do vorbis audio from the specs. Found Popcorn MKV Converter that handled everything automatically, can even do a whole directory of files. Official Site is a bit flaky, http://audioconverter.heartware.dk/ , but found it on a bunch of the free sites, just search on google.
DVD - Western Digital Live
By fugi1967 in forum Newbie / General discussionsReplies: 4Last Post: 7th Dec 2010, 11:04 -
Converting HDTV recordings to MKV - quality issues
By Bully9 in forum Newbie / General discussionsReplies: 24Last Post: 29th May 2010, 12:31 -
Video Archiving using Mp4 - MKV on a Western Digital storage drive
By ejai in forum DVD RippingReplies: 23Last Post: 9th Sep 2009, 22:50 -
Western Digital HD TV Media Centre - Missing audio codec support
By Hcw87 in forum Media Center PC / MediaCentersReplies: 5Last Post: 21st Jul 2009, 13:55 -
western digital hd tv - problem with mkv file
By klus in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd Mar 2009, 23:57
