I have a Philips DVP5990 Upscaling DVD Player and I was wondering what some good picture/audio settings to use.
For what TV?
http://www.kiva.org/about
It's a 46 Inch Sony Bravia
HDMI @ 1920x1080p if the TV takes it, 1920x1080i if not.
If you choose 1080p, the player does the inverse telecine.
If you choose 1080i, the HDTV does the inverse telecine.
Try it both ways from a TV film source (not progressive DVD) and see which does better.
The player will revert to 720x480p for commercial DVD.
You may want to change that to 720x480i if you want the TV to deinterlace TV clips.
Again try both ways and choose.
You see, it all depends on how good the TV is and what type DVD you want to play.Recommends: Kiva.org - Loans that change lives.
What would be the recommended or best settings for playing (R2) PAL DVD on a 1080p HDTV in general and Panasonic PZ85U in particular?
If you are talking about a PAL commercial disc I can't speak to region coding but all such disks will only play at SD resolutions. The HDTV will do the upscale to 1920x1080p. I haven't tested my 5992 yet with PAL discs.Originally Posted by kinemaxRecommends: Kiva.org - Loans that change lives.
So the player up-converts only NTSC and not PAL discs?Originally Posted by edDV
I think the player takes PAL 720*576 down converts to 720*480 then up converts to 1080.
There might be a firmware hack to make it true PAL DVD player.
JVC Svhs 3900 picture settings
By cyber-junkie in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 19:38 -
question about settings on Fair Use Wizard for best picture
By jimdagys in forum DVD RippingReplies: 4Last Post: 18th Oct 2007, 04:13 -
Oppo player picture settings
By samijubal in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Jan 2007, 15:06 -
E30 picture and mpeg-dnr settings
By scottymac in forum DVD & Blu-ray RecordersReplies: 4Last Post: 23rd Nov 2003, 16:30 -
Settings for DVD2SVCD to get best quality picture
By jaded_999 in forum DVD RippingReplies: 2Last Post: 15th Jan 2003, 22:00
