I am unable to copy DVD into a disc but can do it into the hard drive. The burn message displayed burn success but the My Computer showed blank in the drive and DVD player software couln't find the copied disk in the drive. However, there is no problem to play the original DVD movie. If the burner cannot burn the disc but can copy the DVD into the hard drive, could it be burner defective or it is impossible for a defect in the burner?
Results 1 to 9 of 9
It would be helpful if you posted what software you're using to burn dvd media. Also fill in your computer specs in your profile. What's the brand/model of the dvd burner that you have? What brand of dvd media are you using?
I used Nero and Roxio to test it. I do not know the build in burner brand name and it should be unrelated. The problem is if the burner is defective, could it only be unable to copy DVD into the disc but still could do it into the hard drive?
You're using terrible software.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Originally Posted by coody
The brand of your dvd burner can be related. When you use NERO it shows the brand/model of your dvd burner. Or go through the NERO INFO TOOL which will show the brand/model of your dvd burner. What brand of dvd media are you using? DVD media brand is important and I think you've been around this forum long enough to know that by now.
I
with LS that you're using terrible software.
For ripping dvd files use DVDFAB HD DECRYPTER then use DVD SHRINK. Then use IMGBURN to burn dvd media. Use those programs to backup your dvd discs. What dvd disc are you trying to back up?
Your dvd burner laser could be dying as well.
Is there anyone can answer the question directly? If the burner is defective, can it still be able to copy DVD into the hard drive or it will be unable to copy DVD into both of the disc and hard drive?
No.Originally Posted by coody
Wait....Yes.
Opps...I meant NO.
Stop giving vague answers to what is asked of you
if you want people to help you. All of your threads
have the same exact "feel" to them. People ask
questions of you in return so they can better diagnose
the problem.....ANSWER THEM if you want the problem solved.
I'm beginning to think you and member "1234567" are twins.
I'll have a go, but your question needs restating for clarity. :POriginally Posted by coody
*Is it possible for a DVD writer to read discs but not burn them?*
Sure, if it was beginning to fail.
But in your first post you mention trying to copy a movie from "original DVD movie" to a blank. Movie? As in encrypted movie? Or not encrypted? If you're trying to do a direct copy of an encrypted movie, it would fail for sure unless you used something like AnyDVD or DVD43.
At any rate, Nero and Roxio have a long history of conflicting with each other. It may be that later versions are less of a problem, but it's still a bad idea to have multiple burning programs.Pull! Bang! Darn!
Can you stop NO, Yes and then No here though you can play it in the kindergarten if you are good at it?Originally Posted by hech54
JVC SR-S388E S-VHS playback jittery + B&W, diagnosis?
By kbbbb in forum CapturingReplies: 3Last Post: 5th Jan 2012, 20:23 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
Burner won't burn DVDs
By Nephilim in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jan 2008, 16:23 -
My burner used to burn fast enough...but now it doesn't
By Auto Ford in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Nov 2007, 17:10 -
bad HDD diagnosis
By rallynavvie in forum ComputerReplies: 16Last Post: 23rd Oct 2007, 11:33
