I want to buy this to copy commercial DVD's in my own library to have dual copies in case of scratching. I want to be able to burn music cd's and dvd movies. Is this a good choice or will I have a bunch of software and media problems. I have read in other posts on other sites that some have problems with it not reading media or blank disks, but they mentioned having problems due to playing PC games. I dont play PC games. Does anyone have previous usage of the 740 or know of a better choice? Thanks![]()
Read the reviews here:
http://www.cdfreaks.com/reviews/
Also note the media tests. They will tell you what's the best media to use for each burner.
Thank you
HP 740 is such a old model from 2005....you're better off buying a more current model like a PIONEER 116.
Is Vixia HF M30 a good choice?
By twister6 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 7th Jun 2010, 01:32 -
Basic DVD Burning for Mac
By The Monkees in forum MacReplies: 8Last Post: 9th Mar 2010, 17:30 -
what's a good choice for under $1000
By joytimeday in forum ComputerReplies: 3Last Post: 2nd Feb 2008, 15:03 -
Did I Make A Good Choice on My TV?
By tcheema in forum DVB / HDTVReplies: 6Last Post: 18th Jan 2008, 14:06 -
is consumer camcording 16:9 a good choice?
By jmwismer in forum Newbie / General discussionsReplies: 9Last Post: 1st Jan 2008, 20:17
