VideoHelp.com Forum
    I used to be able to play commercial Blu-Ray DVDs in the past with this same hardware configuration, but now when I try to play any Blu-Ray DVD using CyberLink PowerDVD v7.3 Ultra (latest updates, latest patches, full Hi-Def/Blu-Ray support), I receive the following error message from PowerDVD:
    Fail to enable HDCP. Please switch to analog output (VGA, D-Sub) and try again.
    - (Error Code = 0107)
    Please run the BD/HD Advisor tool for more information.
    But that's not supposed to be true! My monitor does support HDCP when connected with a DVI cable (as I have it connected). No other program has ever given me an error message anything like this. Also, I don't have an analog cable to try it that way.
    Here are my relevant high-level configuration details:
    Mobo: Intel DQ35MP / Intel Dual-Core E8400 @ 3 Ghz / 2GB Corsair RAM
    OS: Windows XP Pro SP3
    Video card (substituting for on-board Intel graphics which I don't use): NVIDIA GeForce 8400 GS
    Monitor: Samsung SyncMaster 245BW(Digital) connected via DVI cable.
    The Samsung 245BW digital monitor DOES support HDCP. See: Samsung 245BW Quick Guide and: Full Specs
    Since the error message suggested it, I ran the "BD/HD Advisor tool", and it reported everything was fine except for one item: The Video Connection Type was given as: "Digital (without HDCP)". Here's the report log:
    Check Item BD Ready? Info
    CPU : Intel Pentium III Xeon processor Yes
    __dwItemID=1001__ : szLibCPUName = Intel(R) Core(TM)2 Duo CPU E8400 @
    __dwItemID=1002__ : dwLibClockRate = 2994
    __dwItemID=1003__ : dwLibFamily = 6, dwLibModel=23, dwLibStepping=6
    __dwItemID=1004__ : dwLibNumPhysicalProc = 2, dwLibNumCorePerPackage=2,
    dwLibNumLogicalPerCore=0
    __dwItemID=1005__ : dwLibCorePerPackage = 2, dwLibTotalLogicals=2
    __dwItemID=1006__ : szWMIName=Intel Pentium III Xeon processor
    __dwItemID=1007__ : szWMIManufacturer=GenuineIntel
    __dwItemID=1008__ : dwWMIMaxClockSpeed=2989
    __dwItemID=1009__ : bBatteryExist=0
    __dwItemID=1010__ : szGuess=
    CPU (Hardware acceleration) : NVIDIA GeForce 8400 GS Yes
    System Memory : 2048 MB Yes
    Operating System : Windows XP Service Pack 3 Yes
    Graphics Card : NVIDIA GeForce 8400 GS Yes
    __dwItemID=1301__ : Adapter Compatibility: NVIDIA
    __dwItemID=1302__ : VideoProcessor: GeForce 8400 GS
    Graphics card video memory : 512 MB
    Graphics Card Driver : 6.14.11.8122 Yes
    __dwItemID=1501__ : 2D Driver=6.14.11.8122
    __dwItemID=1502__ : COPP=Yes
    __dwItemID=1503__ : RGBOverlay=Yes
    __dwItemID=1504__ : DEVICE=N/A
    __dwItemID=1601__ : Driver 0:
    __dwItemID=1602__ : [S:] LITE-ON BD B LH-2B1S
    __dwItemID=1603__ : eHCMDrvType=0x002c67c7
    __dwItemID=1604__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=0
    __dwItemID=1611__ : Driver 1:
    __dwItemID=1612__ : [Q:] ELBY CLONEDRIVE
    __dwItemID=1613__ : eHCMDrvType=0x00040fc7
    __dwItemID=1614__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=0
    __dwItemID=1621__ : Driver 2:
    __dwItemID=1622__ : [R:] PIONEER DVR-113NP
    __dwItemID=1623__ : eHCMDrvType=0x00006fc7
    __dwItemID=1624__ : CDRom=1 DVDRom=1 BDRom=0 HDDVDRom=0
    Blu-ray Disc Drive : [S:] LITE-ON BD B LH-2B1S Yes
    Software Player : PowerDVD 7.3.4617a.0 Yes
    Video Connection Type : Digital (without HDCP)
    Program version : 2.0.0609.0
    System language : 0409 ENU English English
    Time : Sun Feb 08 04:49:10 2009
    Computer : Desktop
    Note, however, that Cyberlink warns that the Advisor report may well contain incorrect information (note, for example, that it wildly misreports my CPU - "Pentium III Xeon"??). That's why I wondered if there was some other software tool to check if HDCP is actually enabled and there's some bug in the Cyberlink software when working under my configuration.
    My questions:
    (1) So why am I getting those reports that say that HDCP is not enabled?
    (2) What can I do about it?
    (3) Is there any other way to determine if those reports from the Cyberlink apps are simply bogus? (for example, a third-party test to see if HDCP is enabled and working after all)?
    One other thing: Someone on another forum told me that I had to use HDMI adapters in between for HDCP to work (i.e., DVI->HDMI--->>>HDMI->DVI). That doesn't sound plausible to me, but what do you all think? Or might it be an issue of whether or not I'm using a DVI-D or DVD-I cable?
    Thanks!
  2. Member waheed's Avatar
    Have you trying uninstalling and reinstalling PowerDVD?
  3. Member MOVIEGEEK's Avatar
    You might need AnyDVD running in the background,they add new AACS all the time.I would also update the video drivers.
    Infotool also has a BD/HD DVD test.
  1. Which audio codec I need to enable for playing "cook/ffcook" audi
    By tigerb in forum Newbie / General discussions
    Last Post: 18th Sep 2009, 23:10
  2. DVD5 played by WinDVD and PowerDVD doesnt show "Hide subtitle" op
    By rsb in forum Newbie / General discussions
    Last Post: 22nd Mar 2009, 08:11
  3. question about "ultra-certified" divx
    By maca in forum Newbie / General discussions
    Last Post: 2nd May 2008, 09:39
  4. Replies: 2
    Last Post: 31st Jan 2008, 06:35
  5. Replies: 0
    Last Post: 15th Jan 2008, 04:56
