My Device Manager lists my drive as a Philips DVD+-RW SDVD8441. I am trying to determine if it is the same as the drive listed here. It is the best match I can seem to find.
http://www.videohelp.com/dvdwriters/...-sdvd8441/1290
If you have ImgBurn (Highly recommended) you can check the capabilities of a drive in 'Tools>Capabilities'. If you plan on trying a DL burn, I would also recommend trying only Verbatim DL + discs.
And welcome to our forums.
I was looking at the displayed info from IMG under the device tab in Build mode...I should have just kept nosing around some more. After such a long time of flawless operation, I forget 95% of what it has to offer.
Looks like it does support DVD+R DL writing. Must be the same drive.
Many Thanks.
This drive is a bad choice.
Don't expect anything good especially when burning DL.*** Now that you have read me, do some other things. ***
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Burning to dual Layer discs
By Mastablastacious in forum DVD RippingReplies: 19Last Post: 5th Feb 2008, 18:50 -
Having trouble with dual layer discs
By red69 in forum Authoring (DVD)Replies: 6Last Post: 8th Sep 2007, 04:16 -
Getting I/O Errors While Burning Dual Layer Discs
By VanCity in forum Newbie / General discussionsReplies: 5Last Post: 31st May 2007, 23:35
Statistics
Newest guides
Latest tool updates
New media comments
