VideoHelp.com Forum
    hi all, new here. I've always used Ripbot264. My problems is that got a new hard drive and reinstalled everything and now
    Ripbot continues to show that Haali Media Splitter isn't installed.
    Never had this problem before. I have Netframework installed, along with Ffdshow and Haali so I'm at a stand still.
    Vista x64 ultimate.
    edit the .ini file.
    //RipBot264 will check if AviSynth, FFDshow and Haali Media Spliter are installed and will also check account type
    CheckRequiredSoftware=0
    it wont complain any more.
    Thanks Romi. That did the trick for that part. I don't know what it is but
    it just doesn't seem to want to work for me. Load the file, goes through
    the process of demuxing and such, then media player classic pops up
    and says "opening" and that's all. I'm at the point where I just might call it
    quits. This has always been so simple. Now it's seems impossible to get it
    to work. Thanks again
    i would suggest u use v1.12 for now as the latest version has a few niggles. all the best.
    edit: also, reinstall avisynth, ffdshow, haali.
    I'll try that and see how it goes. Thanks again
    everything is working fine now. Installed 1.12 and all is well. Thanks for the help Romi.
    no probs.
  1. RipBot264/MP4Box error
    By netninja2001 in forum Blu-ray Ripping
    Last Post: 10th Feb 2011, 07:53
  2. ripbot264 error
    By micky46 in forum Blu-ray Ripping
    Last Post: 23rd Sep 2009, 00:08
  3. Replies: 9
    Last Post: 28th Apr 2009, 18:31
  4. RipBot264 error in MPC crashes re-encode
    By gonzalu in forum Blu-ray Ripping
    Last Post: 6th Apr 2009, 15:52
  5. DirectShowSource error in Ripbot264
    By reiter der hoelle in forum Blu-ray Ripping
    Last Post: 15th Dec 2008, 02:22
