VideoHelp.com Forum
  1. Hi folks,
    Dumb question, perhaps, but I see a lot of people out there are encoding various roughly 2-hour Bluray movies to 720p mkv (264, AC3) at either 4.37gb or 6-8gb...
    ...I'm trying to work out which datarate I should generally go for myself, and the 4.37gb mkv files I've seen look fine (usually around 4500kbps video rate) and are obviously convenient for single-layer DVD backup.
    Is there something I'm missing, or should I be considering a higher bitrate like some of the other encoders out there? To me, it looks like the higher bitrate is generally just wasting bits?
    I mean, I'd guess even if you disregarded bitrate and encoded at a 264 constant rate factor of 59-62%, you'd still end up less than 4.38gb, more often than not - maybe I'm completely wrong on that tho - maybe that is why some movies blow out to 6-8gb?
    Cheers,
    Broad
  2. Member Soopafresh's Avatar
    Depends on your own eyes - if you're happy, that's all that counts. Another factor is the type of scenes in the video. Any movie with lots of water, smoke, or fog scenes needs a lot of bitrate in order to avoid macroblocking.
  3. Star Fields will also need big bitrate.. something like the Enterprise going into warp mode
    "LaaaLaaaaaa Where no man has gone before ...SHOOM!"
    The electronic components of the power part adopted a lot of Rubycons.
  1. Replies: 4
    Last Post: 17th Feb 2010, 17:21
  2. Authoring Double Layer DVDs for personal recordings
    By soneman in forum Authoring (DVD)
    Last Post: 30th Aug 2009, 05:18
  3. Replies: 5
    Last Post: 25th Aug 2008, 01:02
  4. do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
    By cduval04 in forum Newbie / General discussions
    Last Post: 24th Oct 2007, 10:40
  5. Replies: 3
    Last Post: 28th May 2007, 16:19
