VideoHelp.com Forum
    i have several avi clips i want to put into one. whats a simple program i can use to do this?
    i have virtual dub 1.8.8 but it cant put several avi clips together.
    Yes, it can under File->Append, but they must have exact same settings. If not then use an "advanced" editor like windows movie maker, ulead videostudio, adobe premiere elements, etc.
    that append option was never functional but now i know why. you can tell im a total newbie lol. thanks.
  4. Member PuzZLeR's Avatar
    If you rename the files you wish to combine to something like "01.avi", "02.avi", "03.avi", ... , etc they will be joined in one step, in that order.
    Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
  5. VH Wanderer Ai Haibara's Avatar
    Isn't AVIDemux a slight bit more flexible than VirtualDub in joining AVIs?
    Yes. Like Baldrick said, the files have to have the exact same properties for Virtualdub to work. A file with a framerate of 29.970 will not join with a file with a framerate of 29.970000000000000000001 even if they're from the same clip and you created them with Virtualdub. I've been begging Phaeron for years to fix this but it's not on his priorities list.
  1. Program for simple editing and burning
    By hodocka in forum Newbie / General discussions
    Last Post: 24th Jan 2011, 22:16
  2. simple editing program
    By devdev in forum Editing
    Last Post: 4th Jun 2009, 07:40
  3. extremely simple editing program?
    By Mikrokosmos in forum Editing
    Last Post: 31st Jul 2008, 16:27
  4. Simple free program editing.
    By Traveller in forum Editing
    Last Post: 24th Oct 2007, 00:42
  5. A basic, simple video editing program?
    By Salva Veritate in forum Newbie / General discussions
    Last Post: 25th Jul 2007, 14:50
