VideoHelp.com Forum
    does anyone have one of these? I am just wondering how long a 45 minute video takes to go from camcorder to a final dvd.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Interesting device, but wrong forum. Moving you to DVD Recorder Forum.
    Saw this info on the device: Sony DVDirect VRD-MC5:
    • Stand Alone Operation
    The burner can operate on its own, without the need for a computer connection. This allows you to archive your videos or pictures to DVD without even owning a PC. The built-in LCD screen even allows you to preview videos or pictures as they record.
    • Video and Slideshow Burning
    The burner allows you to import video via S-Video, Composite, USB or FireWire connections. This allows you to connect almost any camcorder to the burner to archive your home movies to DVD. A memory card reader that supports Memory Stick, SD, SDHC, xD, and Compact Flash allows you to burn pictures from your digital camera as a DVD slideshow.
    • High-Definition Video Support
    The DVDirect supports Sony's AVCHD high-definition video format. It can capture and compress this video format using H.264, allowing you to put up to 95 minutes of HD video onto a standard DVD. This disc can be played back in 1080i resolution on Blu-ray disc players.
    But the device has been around a while. Via FireWire to the recorder will be in real time, IE, the running time of the video. Conversion is likely quicker than that, then you add in burning time.
    Thank you. What I'm hoping for is someone who has used this to tell me it can d/l a 45 min video and make a dvd in about 15 minutes...My Mother's JVC unit (similar) can do it in bout 20. Anyone know for sure?
  1. Replies: 8
    Last Post: 27th Aug 2011, 18:41
  2. Replies: 12
    Last Post: 6th Jan 2011, 06:56
  3. Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
    By mek in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Oct 2010, 13:35
  4. Replies: 4
    Last Post: 11th Dec 2009, 17:45
  5. Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
    By UltimateEnd in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Oct 2009, 11:00
