im running an acer al2216w through a nvidia geforce 8800gt.for some reason the monitor will not let me manually adjust the clock/focus or the screen position.it shows up under the ocd but the boxes are blanked out and will not let me select them.i also cannot adjust screen position on the acer with the nvidia control panel.the focus thing would be nice to play with but adjusting screen position is most important as i have one of those "little white lines" at the bottom of the screen.i have looked but found nothing specifically addressing the issue.any tips or advice,other than "you should not downgrade your video cards display" is appreciated.im sure one or the other is canceling out the other.hope i put this post in the right section.thanks
i just found out you can only make that adjustment in "analog"mode
Dvi not working on acer monitor
By kruzing in forum ComputerReplies: 2Last Post: 6th Oct 2011, 15:44 -
adjust dvd subtitle position
By pcb in forum SubtitleReplies: 1Last Post: 27th Aug 2008, 18:42 -
Adjust vertical 'position' on HD capture
By Hardcore Legend in forum DVB / HDTVReplies: 4Last Post: 12th Oct 2007, 13:30 -
Acer 22" Wide Screen Monitor $179 at Office Depot
By ebenton in forum ComputerReplies: 8Last Post: 20th Aug 2007, 15:03 -
Question: How to adjust the position of ASS subtitle format?
By FulciLives in forum SubtitleReplies: 2Last Post: 22nd Jul 2007, 00:24
Statistics
Newest guides
Latest tool updates
New media comments
