VideoHelp.com Forum
  1. Hi guys,
    I have a movie in avi file without the subs. I downloaded the subs and then got it to play along with the avi file...it shows up in regular subs as you would normally see it but it also shows up in the bottom left in small text subs also. How can I get rid of the extra small text subs?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Do you have VSFilter / DirectVobSub installed? If so and you are using a player that has it's own sub software you may have duplicate subs. You would need to turn one of them off.
  3. I am using WMP 11 to watch my movies. I do have AutoGK and VobSub installed if that makes a difference. I can turn on/off the normal subs but cant seem to get rid of the small text ones that appears not in the movie (its located on the bottom left...in the black area).
    Maybe burned in subtitles? Or do you have another subtitle filter installed like ffdshow.
  5. Originally Posted by Baldrick
    its definitely not burned in subs because i encoded the avi to not have any subs. then realized that i might need it in the future so i went and download the subs and put the subs into the same folder as the avi.
  6. when i play the avi, it uses the ffdshow audio/video encoder and also the directVobSub too.
  7. VH Wanderer Ai Haibara's Avatar
    Go to the ffdshow folder in your Start menu, and click on either "VFW configuration" or "Video decoder configuration". In the window that pops up, look for the Subtitles header in the left pane, and remove the checkmark from the box next to it, if it's there. Click OK to clear the window, then repeat the process with the other configuration window (for example, if you picked "VFW configuration" first, open "Video decoder configuration" next.) Then, see if that removes one of the duplicate subtitle instances.
  8. Still no good...maybe its the program that I used to encode the video to avi? I used DVDFab Platinum.
  1. Weird Problem - Adding subs to avi doesn't work okey on DVD Player
    By andreas.cro in forum Newbie / General discussions
    Last Post: 27th Mar 2012, 08:58
  2. Adding subs to avi in virtualdub with textsub
    By djgazzabhoy in forum Video Conversion
    Last Post: 26th Nov 2011, 05:04
  3. Adding subs to avi format?
    By Avon in forum Subtitle
    Last Post: 14th Aug 2011, 12:20
  4. Replies: 5
    Last Post: 29th Dec 2009, 18:01
  5. Adding subs to a .avi file
    By stgdlf in forum Newbie / General discussions
    Last Post: 21st Nov 2009, 00:34
