I changed the topic subject. I shouldn't have to open the topic to read what it's about.
What profile did you use?
Or try stream using PS3 Media Server.
Sorry, thanks. I chose .mp4. I suppose I could do .mkv and use the .mkv converter? I really like using tversity for my server but you think ps3mediaserver is good? I am work now but currently am converting the 22gb .m2ts in divx converter under 720p profiel while im gone just to see what that does also. I basically am just looking to get this .m2ts shrunk and playable over my network. Thanks again.
I think i might try the bd to xvid method also. Will see what I find when I get home under the divx converter.
I'm confused. You mention going from M2TS to MP4 but the Sony PS3 supports M2TS so there should be no need for conversion.
Footnote: I've never used RipBot264 ... instead I use XVID4PSP which has always created MP4 files that work on my PS3 without fault. XVID4PSP also supports M2TS output so if you simply want to re-encode to make a M2TS smaller then you can go from M2TS to M2TS and thus not have to fool with an audio conversion (as would be needed with M2TS to MP4).
Ill try it. Yes, i have an .m2ts thats 22GB, playable onps3, but wish I could make it smaller.
Need help-Been using ripbot for sometime now....it has stopped working.
By clefus in forum Blu-ray RippingReplies: 3Last Post: 13th Jan 2011, 11:42 -
Ripbot - TrueHd stream related error
By Mitchmitchel in forum Blu-ray RippingReplies: 0Last Post: 11th Jun 2010, 17:07 -
x264_x64.exe has stopped working. (Ripbot 1.15.1) Help.
By theshadow1234 in forum Blu-ray RippingReplies: 4Last Post: 19th Mar 2010, 14:57 -
Question about ripbot and profiles and ps3
By ultraman36 in forum Blu-ray RippingReplies: 0Last Post: 17th May 2009, 05:40 -
Ripbot wont start....
By Fiostech in forum Blu-ray RippingReplies: 13Last Post: 4th Feb 2009, 12:01
