Hi, I have been doing some encoding tests using ffmpegX making h264 clips for a flash video site.
I seem to be getting a color shift and was wondering if anyone knew what color space ffmpeg assumes and also the gamma.
There doesn't seem to be any way to access this using the ffmepgX interface - would I have more luck using the terminal?
Not many video file formats support color management but I thought maybe if I knew what ffmpegX was using I could set things up and adjust for that to avoid the shift.
Basically my files appear with a little bit too much contrast and they seem a little redder.
Cheers!
Results 1 to 1 of 1
ffmpeg output prores causes color shift
By liutszho in forum ffmpegX bugs and suggestionsReplies: 1Last Post: 4th Jan 2012, 22:22 -
TBC-1000 inducing weird color shift?
By bigass in forum CapturingReplies: 10Last Post: 18th Dec 2011, 15:06 -
[SOLVED] Weird difference in gamma(color) output
By ladjack in forum Software PlayingReplies: 1Last Post: 7th Mar 2011, 07:16 -
ADVC-55 and color shift?
By pgoelz in forum CapturingReplies: 28Last Post: 16th Mar 2010, 17:10 -
Taping a projector slide presentation -- color shift :?:
By shieber in forum Camcorders (DV/HDV/AVCHD)Replies: 6Last Post: 28th Nov 2008, 14:07
