VideoHelp.com Forum
Thread: Playback is bad
    I have recorded 150 old movies from the TV. I have played many of them in the past with no problems. Now all of a sudden almost everyone starts OK but within a minute they start hanging up or getting all chopy or fuzzy like someone spilled something on them. I tried playing them on a friends DVD and it's the same. I've used all kinds of DVD's. Sony, HP, Memorex etc. What caused this?
    I love old classic movies and it makes me sick that I've lost them. Please help!
    Mark
  2. Do they have labels on them? Labels often cause problems down the road.
  3. Always Watching guns1inger's Avatar
    A few of those brands (memorex, HP) I wouldn't trust for longevity and reliability. However, the way discs are stored can have an impact. They should be stored in a dark, dry space. They should be in cases, although you can use the soft covers if stored properly. One of the issue with some of the folders with pockets is that they don't keep the discs flat, and over time they develop a bow and don't play correctly.
    And yes, labels are a no-no.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Member MOVIEGEEK's Avatar
    If you have labels on them use warm water and soap to remove them,then use DVDFab Decrypter or IsoBuster to rip them to your PC.
  5. Member victoriabears's Avatar
    The effort to remove labels might be balanced against paying 30 cents for taiyo yudens and copying them.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    Thanks for all replies. No labels. They are in hard cases and upright. If they have become bowed, is there a fix?
    Mark
  7. Member MOVIEGEEK's Avatar
    You could soak them in hot water(120F) for ten minutes then set a heavy book on them,I did this once and it worked.
    Here's an article by the US gov. that states you should store discs vertically but says optical media will only last 2-5 years:
    http://www.archives.gov/records-mgmt...media-faq.html
    Thanks MOVIEGEEK. I'll give it a try!
    Mark
  1. No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
    By koberulz in forum Newbie / General discussions
    Last Post: 24th Jan 2010, 04:48
  2. Bad .vob .mpg file playback, colors messed up
    By lindylex in forum Editing
    Last Post: 30th Dec 2009, 09:56
  3. bad playback mini DV tape
    By izzykatz in forum Newbie / General discussions
    Last Post: 15th Aug 2009, 14:20
  4. Bad motherboard or bad CPU?
    By videohalp in forum Computer
    Last Post: 9th Jul 2008, 10:07
  5. Bad encoding? Bad installation
    By lo-q in forum ffmpegX bugs and suggestions
    Last Post: 22nd Sep 2007, 19:45
