Hello Everyone
There is this thing about TV Series I have seen that really bufles me.
I have seen a complete season of a TV series of about 20 episodes each running for about 45 min being put on a single dvd of 4.7 GB size and this really bufles me.
I want to know if it is that there is a special authoring program they are using or it is that they get to significantly reduce the size of each episode but still mentain an appreciable quality andthen burn them into one 4.7 GB dvd.
I will be very glad if somebody can help me solve this mystery.
Thanks all you guys on videohelp for your wonderful contribution to this forum.
file size = bitrate * running time
The lower the bitrate the lower the quality. You can use smaller frame sizes to reduce the bitrate requirement. For example, use 352x288 or 352x576 instead of 720x576.
If you are using a Divx certified DVD player you can create a DVD full of Divx files which can get ~equivalent quality to DVD at about half the bitrate. You can also reduce the frame size to reduce the bitrate requirement. Divx is much more flexible in terms of frame sizes so you aren't limited to just 352x288, 352x576, and 720x576.
The nature of the video can make a difference too. A 20 hour still frame can compress down to nearly nothing and look decent. High motion, high noise, etc. does not compress well.
As jagabo said, you can put many hours of video on a disc, but there's a tradeoff in quality.
You can use reduced (e.g., VCD-like) resolution and bitrates (both are DVD-compliant, by the way; all that needs to be changed is the audio sampling rate), and that alone will allow you to increase the running time. At VCD rates, you can cram more than 7 hours of video on a single-sided (DVD5) disc. If you're willing to accept even lower quality than VCD, you can go well beyond 7 hours. It all depends on how much reduction in quality you are willing to tolerate. The lower your standards, the longer the running time.
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum CapturingReplies: 0Last Post: 12th Apr 2011, 22:34 -
Need help mapping season episode to grouped chapters on a DVD
By nzdreamer55 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 16:12 -
DVD to complete MPEG2
By neftv in forum Video ConversionReplies: 7Last Post: 22nd Mar 2008, 12:40 -
How many complete tv series do you own?
By yoda313 in forum PollsReplies: 42Last Post: 23rd Feb 2008, 04:18 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
Statistics
Newest guides
Latest tool updates
New media comments
