I may be suffering from information overload here!!!
Managed to rip my purchased copy of a Blu-ray movie to my pc with anydvd.
Ended up with:
BDMV folder
CERTIFICATE folder
PS3 UPDATE folder
PS3_VPRM folder
083624896 zip
083624897 zip
FilmIndex.xml
PS3_DISC.SFB
(Total folder size 41.5.gig)
With your help i an hoping to get this movie in blu-ray quality to my PS3 via external hard drive.
I do not need the movie extras,etc.
Space not really an issue,but i am a bit lost with the next steps to take to do this.
Looked through the guides,but not sure which one to follow.
Appreciate any help pointing me in the right direction.
Regards...Pensioner
Thread: BLU-RAY Ripped
You could use RipBot264 as it should be able to convert to a PS3 format. Or try BD Rebuilder, though I'm not familiar enough with a PS3 to know how it would work. Alternately, you can use tsMuxeR to just select the main movie and the desired audio track and end up with a .m2ts file from the BD. That usually ends up at about 20 - 30 or so gigabytes, but it will be the same quality as the BD disc.
Hmmm,i am still a bit lost here,already have lots of m2ts files.
Is there a step by step guide,i am not wanting to create a disc,just a playable file for my ps3.
Thanks for your patience
Try RipBot264. That should be the easiest way to do what you want.
The PS3 requires the external hard drive to be formatted
in FAT32 and thus limits the filesize to 4 GB.
That leaves you with very hard compressed movies or chopped
in 4 GB parts.
This guide should help:
http://forum.videohelp.com/topic358185.html
Or just put the disk in the PS3...
Regards,
Rob
Best way to view a Ripped Blu-ray
By PHNeedsHelp in forum Blu-ray RippingReplies: 5Last Post: 1st Feb 2012, 22:24 -
Ripped blu-ray. Now what?
By whoisquilty in forum MacReplies: 5Last Post: 2nd Aug 2010, 17:36 -
Q: about playing a ripped blu-ray
By raptor1015 in forum Software PlayingReplies: 1Last Post: 29th Jun 2010, 11:58 -
Subtitles on a DVD from ripped Blu Ray
By fjmr in forum Blu-ray RippingReplies: 4Last Post: 27th Sep 2009, 07:49 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 12Last Post: 15th Oct 2008, 19:51
