VideoHelp.com Forum
Results 1 to 17 of 17
    Hello Chris,
    I have been using your program for more then 3,5 years now, and this is
    my main software. It's been great !!
    I would like to ask you for a help - I have been having troubles adding
    subtitles on DVD made with SVC2DVD , I did not care about it before, but
    recently started to bother me a lot.
    I read all I could find in support forums, but I could not see that this
    issue was definitely addressed & solved.
    I tried checking logs myself, and it appears that subtitles are added,
    however, I can never play it on my DVD. It is NOT DVD issue (I am 1000%
    sure), I have 2 DVD players (Pioneer and Liteon) and both DVD players
    will play subtitles in DVD that I create with software such as DVD Flick
    or ConvertXtoDvd.
    I do not want to use these other programs and I only used them to see if
    I can manage to add subtitles to my DVD.
    I tried every which way I could think of (I know I need to convert .srt
    file to .sup , which I did with Subtitle creator and that file must be
    identically named as movie file ; .. I also tried all kind of other
    subtitles and never had any success)
    I will post 2 log files for your review, I would really IMMENSELY
    APPRECIATE if you could help me and identify the problem.
    svcd2dvdlog-20090129025029.txt
    And here is other log:
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.5
    Version: 2.5.5020.0
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
    Executable size: 2.58 MB
    Executable size in bytes: 2711635
    Executable CreationTime: 18/12/2008 1:37:16 AM
    Executable LastWriteTime: 25/01/2009 3:54:10 AM
    Executable LastAccessTime: 29/01/2009 8:35:28 PM
    ************************* Operating System *************************
    **********************UNABLE TO GET SYSTEM INFO*******************
    ************************* ProjectMetaData **************************
    <?xml version="1.0" encoding="utf-8"?>
    <SVCD2DVD DateTime="29/01/2009 2:50:55 PM" Filename="NONE">
    <AssetSet>
    <Asset ID="4bd55c0f-7f92-4d74-a6cf-234cb2e14079" Path="D:\Movies to work with SVCD2DVD" Filename="Australia 2008 DVDSCR XviD-KingBen.avi" />
    </AssetSet>
    <DVDStructure>
    <TitleSet Name="Australia " PostCmd="" MenuButtonType="0">
    <MenuButton X1="142" Y1="433" X2="337" Y2="486" FontFamily="Tahoma" FontSize="27.75" FontStyle="3">Australia </MenuButton>
    <Title Name="Australia 2008 DVDSCR XviD-KingBen.avi" AssetID="4bd55c0f-7f92-4d74-a6cf-234cb2e14079" MplexOffset="0" />
    </TitleSet>
    <DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="D:\Movies to work with SVCD2DVD\Slike za Film Menu's\Australia .jpg" AudioPath="" />
    </DVDStructure>
    <Settings>
    <General InitialAssetFolder="D:\Movies to work with SVCD2DVD" InitialDVDFolder="D:\DVD folder for SVCD2DVD" OutputFolderName="DVD - READY FOR BURNING" InitialProjectFolder="D:\Project Folder for SVCD2DVD" InitialMenuBackgroundFolder="D:\Movies to work with SVCD2DVD\Slike za Film Menu's" DeleteS2DFiles="True" UseDVDShrink="False" />
    <Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="27.75" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
    <Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
    <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
    <Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" />
    </Settings>
    </SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 1.45 GB
    file=D:\\Movies to work with SVCD2DVD\\Australia 2008 DVDSCR XviD-KingBen.avi
    FormatName=avi
    Num_Frames=235265
    DurationInSecs=9411
    Duration=02:36:50.6
    VideoCodec=mpeg4
    VideoFFSTNum=0
    Width=704
    Height=304
    Standard=PAL
    BitRate=1332
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1StreamID=[0x1]
    Audio1SampleRate=44100
    Audio1Codec=mp3
    Audio1BitRate=192
    Audio1Channels=2
    AVI2MPG: 3408kbs Full-D1
    14:50:55: Looking for AVI PAR...
    Pass 1/1: Processing Australia 2008 DVDSCR XviD-KingBen.avi
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: libavutil 49.12. 0 / 49.12. 0
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: libavcodec 52. 6. 0 / 52. 6. 0
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: libavformat 52.23. 1 / 52.23. 1
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: libavdevice 52. 1. 0 / 52. 1. 0
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: libswscale 0. 6. 1 / 0. 6. 1
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: [NULL @ 0x3cb60]Invalid and inefficient vfw-avi packed B frames detected
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Input #0, avi, from 'D:\Movies to work with SVCD2DVD\Australia 2008 DVDSCR XviD-KingBen.avi':
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Duration: 02:36:50.64, start: 0.000000, bitrate: 1332 kb/s
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Stream #0.0: Video: mpeg4, yuv420p, 704x304 [PAR 1:1 DAR 44:19], 25.00 tb(r)
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Output #0, dvd, to 'D:\Movies to work with SVCD2DVD\Australia 2008 DVDSCR XviD-KingBen_S2D.mpg':
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 3408 kb/s, 25.00 tb(c)
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Stream mapping:
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Stream #0.0 -> #0.0
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Stream #0.1 -> #0.1
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: [mpeg2video @ 0x16e6010]Using pulldown for PAL->NTSC.
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: Press [q] to stop encoding
    [Australia 2008 DVDSCR XviD-KingBen] 14:50:58: [mpeg4 @ 0x3cb60]Invalid and inefficient vfw-avi packed B frames detected
    [Australia 2008 DVDSCR XviD-KingBen] 18:00:59: video:3914467kB audio:514644kB global headers:0kB muxing overhead 2.433441%
    18:01:02: Done: Processing assets for DVD creation
    Authoring DVD Folders
    18:01:03: Creating TitleSet # 1
    18:01:04: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    18:01:04: -->: DVDFolders creating VTS
    18:01:04: -->: VTS 01
    18:01:04:
    DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2.5\dummymenuNTSC.mpg...
    18:01:04:
    DVD Folders: Processing D:\Movies to work with SVCD2DVD\Australia 2008 DVDSCR XviD-KingBen_S2D.mpg...
    18:12:42:
    18:12:43:
    18:16:02:
    18:16:02: Finalising DVD...
    18:16:03: Encoding menu...
    ---------------------------- ENCODING MENU ----------------------------
    TV Standard: NTSC
    Aspect Ratio: 4:3
    Image size: 720x540
    Resize size: 720x480
    [] 18:16:14: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [] 18:16:14: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [] 18:16:14: libavutil 49.12. 0 / 49.12. 0
    [] 18:16:14: libavcodec 52. 6. 0 / 52. 6. 0
    [] 18:16:14: libavformat 52.23. 1 / 52.23. 1
    [] 18:16:14: libavdevice 52. 1. 0 / 52. 1. 0
    [] 18:16:14: libswscale 0. 6. 1 / 0. 6. 1
    [] 18:16:14: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [] 18:16:14: Input #0, image2, from 'C:\\Documents and Settings\\Owner\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5020.0\\menu\\background1.jpg':
    [] 18:16:14: Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
    [] 18:16:14: Stream #0.0: Video: mjpeg, yuvj420p, 720x480 [PAR 96:96 DAR 3:2], 25.00 tb(r)
    [] 18:16:14: Output #0, rawvideo, to 'C:\\Documents and Settings\\Owner\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.5020.0\\menu\\backgroundES.mpv':
    [] 18:16:14: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 6000 kb/s, 29.97 tb(c)
    [] 18:16:14: Stream mapping:
    [] 18:16:14: Stream #0.0 -> #0.0
    [] 18:16:14: Press [q] to stop encoding
    [] 18:16:15: video:133kB audio:0kB global headers:0kB muxing overhead 0.000000%
    18:16:16: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    18:16:16: INFO: [???] File C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.5020.0\menu\backgroundES.mpv looks like an MPEG Video stream.
    18:16:16: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    18:16:16: INFO: [???] Found 0 audio streams and 1 video streams
    18:16:16: INFO: [???] Selecting dvdauthor DVD output profile
    18:16:16: INFO: [???] Multiplexing video program stream!
    18:16:16: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.5020.0\menu\backgroundES.mpv)
    18:16:16: INFO: [???] VIDEO STREAM: e0
    18:16:16: INFO: [???] Frame width : 720
    18:16:16: INFO: [???] Frame height : 480
    18:16:16: INFO: [???] Aspect ratio : 4:3 display
    18:16:16: INFO: [???] Picture rate : 29.970 frames/sec
    18:16:16: INFO: [???] Bit rate : variable
    18:16:16: INFO: [???] Vbv buffer size : 212992 bytes
    18:16:16: INFO: [???] CSPF : 0
    18:16:16: INFO: [???] SYSTEMS/PROGRAM stream:
    18:16:16: INFO: [???] rough-guess multiplexed stream data rate : 0001248
    18:16:16: INFO: [???] target data-rate specified : 10080000
    18:16:16: INFO: [???] Setting specified specified data rate: 10080000
    18:16:16: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 15876
    18:16:16: INFO: [???] New sequence commences...
    18:16:16: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
    18:16:16: INFO: [???] STREAM e0 completed @ frame 14.
    18:16:16: INFO: [???] Multiplex completion at SCR=10240.
    18:16:16: INFO: [???] Video e0: buf= 135465 frame=000014 sector=00000068
    18:16:16: INFO: [???] VIDEO_STATISTICS: e0
    18:16:16: INFO: [???] Video Stream length: 136189 bytes
    18:16:16: INFO: [???] Sequence headers: 2
    18:16:16: INFO: [???] Sequence ends : 0
    18:16:16: INFO: [???] No. Pictures : 15
    18:16:16: INFO: [???] No. Groups : 2
    18:16:16: INFO: [???] No. I Frames : 2 avg. size 45988 bytes
    18:16:16: INFO: [???] No. P Frames : 14 avg. size 3106 bytes
    18:16:16: INFO: [???] No. B Frames : 0 avg. size 0 bytes
    18:16:16: INFO: [???] Average bit-rate : 2040400 bits/sec
    18:16:16: INFO: [???] Peak bit-rate : 1352400 bits/sec
    18:16:16: INFO: [???] BUFFERING min 105096 Buf max 135471
    18:16:16: INFO: [???] MUX STATUS: no under-runs detected.
    create sub file....done.
    running menu muxer....18:16:22: MUXRATE =4400
    18:16:22: after read_bmp(): xd=720 yd=480 x0=0 y0=0
    18:16:22: Found EOF in .sub file.
    18:16:22: warning, sub on line 0 starts before 4s, (some players won't show it)
    18:16:22: subtitle duration: -1
    18:16:22: ***************** HERE WE GO EVE.ODD *******************
    18:16:22: MenuType: EVEN
    18:16:22: subtitle_packet_size: 755
    18:16:22: subtitle_packet_size & 1: 1
    18:16:22: subtitle_packet_size mod 2: 1
    18:16:22: MenuType==""
    18:16:22: MenuType=="EVEN"
    18:16:22: WAS ODD
    18:16:22: subtitle_packet_size++
    18:16:22: final subtitle_packet_size: 756
    18:16:22: max_sub_size=756
    18:16:22: subtitle inserted at: 0.176400 sd=0
    18:16:22: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
    done.
    18:16:22: Encoding menu...Done.
    18:16:22: SVCD2DVD: DVDfolders
    18:16:22: -->: DVDFolders creating table of contents
    18:16:22: scanning D:\DVD folder for SVCD2DVD\DVD - READY FOR BURNING\VIDEO_TS/VTS_01_0.IFO
    18:16:22: -->: Creating menu for TOC
    18:16:22:
    DVD Folders: Processing C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.5020.0\menu\menu.mpg...
    18:16:22:
    18:16:22:
    18:16:23: Finalising DVD...Done
    18:16:23: Done: Authoring DVD Folders
    Burning DVD folder
    18:16:23: Burning DVD with ImgBurn...
    18:50:46: Burning ISO...Done
    18:50:46: Done: Burning DVD folder
  3. Member ChrissyBoy's Avatar
    What is the file name of your subtitle file?
    I believe one file had title : "Australia 2008 DVDSCR XviD-KingBen.sup " and another file was "Snakes.On.A.Plane[2006]DvDrip[Eng]-aXXo.sup" .
    I addition, I did an experiment today -with latest version of SVCD2DVD , so I made a little DVD movie, where I where I worked with movie file named as "A" and subtitle file was "A.sup" . Both files were in the same folder and nothing else was in that folder.
    I uploaded this log file too - please see further below.
    Again, Log file shows that subtitle was inserted (please see:
    " 08:56:44: Adding subtitle stream
    08:57:33: SupMuxer: Done. )
    But once again, neither of my 2 DVD players could display the subtitles, and I could not see subtitles on computer either with latest version of VLC media player.
    svcd2dvdlog-20090203085010.txt
  5. Member ChrissyBoy's Avatar
    ok. Can you please zip up the files required for the experiment and email them to me - i will take a look at this end.
    Did you mean- you need both both video file and subtitle file ? Or you meant only subtitle file ?
    O.K. Chris,
    as you asked I sent you an email with win rar file with one small movie sample which I used for experiment.
    I did following:
    I cut out small portion of movie "the Reader" , approximately about 3 min long
    Then I did the same with subtitles.
    Next, I processed subtitle (.srt file) and converted it to .sup (subtitle) file, using
    Subtitle Creator.
    I placed everything in the same folder, meaning I put avi file, .srt file, and
    . sub file in the same folder & processed everything with SVCD2DVD. Files were named as:
    "the Reader.avi" , "the Reader.srt" & "the Reader.sup"
    (log file indicates that subtitles were added)
    Then I burned project on DVD and tested it on my 2 DVD players (Lite on DVD player/recorder
    and Pioneer DVD Player), and neither one could display the subtitles.
    Please see log : " svcd2dvdlog-20090205220440 " (in email). This is when I worked with 3 files ( avi file,
    .srt file, and . sub file in the same folder)
    ____________
    Next, just in case I repeated all this, but this time I excluded .srt subtitle file in the
    "experiment folder" , but the final result was exactly the same, i.e. no subtitles showing
    Please see log : " svcd2dvdlog-20090205214257 " (in email) This is when I worked with 2 files ( avi file,
    ________________
    Finally, I processed the very same assets with DVD Flick , and the result was success - meaning
    I could see the subtitles on DVD (selectable subtitles that is)
    Hopefully you can take a look at this and figure out what is going on ?
    Your help is very much appreciated !!!
    Kind Regards
    svcd2dvdlog-20090205214257.txt
    Update,
    I sent you an email few times, but it keeps coming back to me with messege : "5.1.0 - Unknown address error 552-'Message size exceeds maximum allowed size of 10485760'
    So, to overcome this, I will upload file(s) to my web file storage and will send you link in email that you can download all the files. Please check you email for download link
    Chrisseyboy, I am still waiting to hear from you.
    Chrisseyboy, 2 weeks ago I sent you all info you asked for (in order to look into the issue). I am disappointed to see that you did not respond yet. Years ago (when i first signed up with you) , it seems you would try to answer questions and help with issues much more then now days.
    I could be wrong , but this strongly suggest that your customer support (once impecable customer service) is going down the drain....
  10. Member ChrissyBoy's Avatar
    Still waiting for your link!
    I am sending link again , please check your email and your PM for instructions how to download files.
    O.K. ChrissyBoy ,
    I can now confirm that I sent you requested link again.
    To insure that you will get link with 100% certainty, link was sent to you 3 times :
    1. directly from Web-a-File
    2. forwarded to you by email
    3. sent to you via PM
    Looking forward to hear from you.
    Thanks in advance !
  13. Member ChrissyBoy's Avatar
    Got it thanks.
  14. Member ChrissyBoy's Avatar
    Ok works fine.... The sup file you sent was PAL, yet the DVD is NTSC. So basically the subs are off the bottom.
    Make a NTSC sup file:
    And you will get the subs as normal:
    Thanks ChrissyBoy !!!! Your help is much appreciated !!!!
    I did as you said and it works. I can not believe my eyes how simple was the solution.
    chrifili
    P.S. Just one last question - I think that with SVCD2DVD I can add one subtitle to a DVD , I can not add multiple subtitles (i.e. subtitles in multiple languages). Am I right about it or there is way to add multiple subtitles ??
  16. Member ChrissyBoy's Avatar
    Correct. Not at the moment.
    Thanks again for supper fast answer !!!
  1. Replies: 1
    Last Post: 19th Nov 2010, 08:23
  2. Problem adding subtitles to DVD
    By makoto in forum ffmpegX general discussion
    Last Post: 15th Sep 2008, 13:25
  3. Problem with the guide for adding subtitles
    By AORMan in forum Subtitle
    Last Post: 13th Jun 2008, 14:50
  4. Replies: 15
    Last Post: 21st Oct 2007, 02:52
  5. a problem with adding subtitles to avi file by autoGN
    By 3l8x in forum Newbie / General discussions
    Last Post: 16th Jun 2007, 01:28
