I'm sorry if this question has been asked/answered before.
I bought this LG GH22LP20 16X and upgraded the firmware to 1.02, using 80pin IDE cables, and set this drive to Secondary Master. Cable is plugged straight from mother board. BIOS settings are set to DMA (auto,4), Windows show DMA when available.
But for all the things I've tried, I can NEVER get it to burn a DVD-R more than 2X (burning an .ISO file). The average is always around 1.2X, with maximum at 1.4X (~2MBps). I used Verbatium 16X DVD-R.
Can someone please tell me what's wrong, and how to fix it? It's really a pain to burn a DVD for 45 mins. It burns CD-R just fine (~3 mins for a full audio CD).
Nero, or ImgBurns, or Active Burn always show the same burning speed.
Please help me. I'm desparate for speed.
Thanks so much for your time and help. I appreciate it.
DN
Very odd. Before doing anything else, I'd try a different brand/type of media. Although the drive is new enough that it shouldn't matter, it is easy enough to eliminate. Aside from that, try a different cable, ensure the drive is connected to the end connector, and try deleting/removing the drive and the IDE controllers from Device Manager and rebooting.
Google is your Friend
I have an LG H58N that is a bit slow to burn....I don't mind....but 1.4X is terrible.
Pcie 1x tuner in 16x slot: PC won't shutdown :(
By TheFamilyMan in forum ComputerReplies: 0Last Post: 21st Jul 2011, 17:51 -
LG GH22LP20 DVD writer
By smartel in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Mar 2011, 09:52 -
LG GH22LP20 lightscribe problem
By RC_cat in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jun 2009, 08:20 -
LG GH22LP20 problem
By Gyongyi in forum DVD & Blu-ray WritersReplies: 3Last Post: 17th Sep 2008, 12:25 -
Should I burn 16x discs at 8x?
By sky captain in forum Authoring (DVD)Replies: 22Last Post: 19th Dec 2007, 21:58
Statistics
Newest guides
Latest tool updates
New media comments
