VideoHelp.com Forum
  1. Hi everyone, I searched my subject line and didn't find an answer so if this topic has been discussed, i am sorry to make you read more. Anyway, my problem is this: Xilisoft Video Cutter the program I am using to cut a file comes up with a little of the bottom cut off like from about half of the destination folder on down however far it goes. And then it even gets covered up by the taskbar, and when I try and move the program up to where i can see the destination folder line the program is automatically pulled right back down. I have had other programs do this, though I cannot remember which ones. I have tried to change the resolution and the smaller I make it the that gets cut off. I appreciate any responses. Thanks. -props
  2. Does Anyone have an idea on this, I have a lot of space wasted on stuff I don't need
    Thanks. -props
  3. I never would have thought I was the only one on videohelp that has ever had this happen, but I guess thanks anyway. -props
  1. Xilisoft video converter help
    By paul278 in forum Video Conversion
    Last Post: 18th Sep 2011, 05:12
  2. Xilisoft video converter
    By Vman94 in forum Video Conversion
    Last Post: 12th Jul 2011, 11:35
  3. output resolution xilisoft video encoder
    By KlintIstwood in forum Blu-ray Ripping
    Last Post: 20th Dec 2008, 12:29
  4. Xilisoft video converter help
    By burgkev in forum Video Conversion
    Last Post: 16th Mar 2008, 16:32
  5. Destination Folder
    By Gripweed in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Jul 2007, 12:28
