Results 1 to 11 of 11
  1. Is it possible to output audio over the HDMI connection and the Optical Output connection on the PS3 at the same time? I have the hdmi cable hooked up to the tv and the optical cable hooked up to the a/v receiver (doesn't accept hdmi inputs). I don't always want to turn on the a/v receiver when I watch a movie. Right now, I have to go into the audio settings on the ps3 and switch back and forth from hdmi and optical. Can both be enabled at the same time, or do I manually have to change it to optical when I want surround sound??? Thanks in advance.
    No. It is an either/or situation. You are stuck with manually changing the audio output settings. I am in the same boat as I am not ready to replace my pre-HDMI amp at this time.
    FWIW, it is not the only issue of this type. I have CoD4, which supports 1080p video - only if you disable 720p and 1080i first. Which is fine, except that if you do this, all 720p games play at 480p because 720p has been disabled, so if I want to play CoD4 at 1080p, I have to manually switch off 720p, then put it back on afterwards.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member yoda313's Avatar
    I don't believe that's possible. As far as I know you have to manually switch them. I know I do whenever I go from the hdmi audio on the ps3 (to my hdtv - I don't have a hdmi receiver just the input on my hdtv) to the fiber optic out on the digital amp - prehdmi amp.
    Sorry it's a pain but I don't think you can dual output them.
    If you find a solution please let us know.
    @guns1inger - ouch that sucks! having to change resolutions for one game????
  4. Originally Posted by guns1inger
    Thanks for the response. Why do you have to disable 720p and 1080i? I have the ps3 setup to output up to 1080p, but I haven't disabled any other resolutions. Shouldn't that take care of it?
  5. Originally Posted by yoda313
    Maybe is enough people complain to sony, they'll release a firmware update that enables both...
    yeah, like that will ever happen.
  6. Always Watching guns1inger's Avatar
    Nope. The default mode for CoD4 is 720p. If you have that enabled, it will use it, even if 1080p is enabled. Not sure if it is a PS3 issue, or just a CoD4 issue, but there are a lot of posts on the subject out there in googleland.
  7. Is there a way to find out the default video output on each game? It has me wondering if Dead Space is outputting 1080p or 720p.
  8. Always Watching guns1inger's Avatar
    The only way to find out is to use your TV's information display to find out what resolution is being output to it when the game is playing. How is dependent on your TV
  9. Thanks. I'll check next time I'm playing.
    PS3 audio, you have to select to output in HDMI or Optical.
    That is a pain, because most older audio receivers do not have HDMI inputs.
    You can use a HDMI splitter amp and it will convert the HDMI audio to the optical.
    If you have multiple HDMI source including PS3 and have a surround system you can use a HDMI switch and just use the optical outputs and connect thru switch then route it to the AUdio receiver optical input.
    It's a PS3 issue, as it happens to all of the games I've played on it. Every game will output its native resolution. If it supports a higher resolution, and its native resolution (720p for quite a few games - Prince of Persia, etc.) is unchecked, it will upscale. Otherwise, it'll downscale to 480p.
    This is what I've found so far
    - Bioshock - outputs natively in 1080p
    - Marvel: Ultimate Alliance - 1080p
    - Prince of Persia - 720p, will upscale to 1080p (looks cleaner and smoother, actually)
    - Ratchet & Clank Future - 720p, will upscale to 1080p (even though that's not specified on the back of the case)
    - Little Big Planet - 720p, will downscale to 480p
    - SvR 2009 - 720p, will downscale to 480p
  1. Does your sound card need drivers to use optical output?
    By Obamargarine in forum Software Playing
    Last Post: 24th Feb 2009, 14:39
  2. hdmi and av output
    By gunukhan in forum DVD & Blu-ray Players
    Last Post: 1st Aug 2007, 13:04
  3. DVD Player Optical Output
    By jcook5000 in forum DVD & Blu-ray Players
    Last Post: 6th Dec 2006, 12:32
  4. Philips 642 and the Optical Output
    By Scooter_NJ in forum DVD & Blu-ray Players
    Last Post: 12th Jan 2005, 19:07
  5. HDMI and optical output on Denon 3910
    By kocsis in forum DVD & Blu-ray Players
    Last Post: 11th Jan 2005, 11:11
About   Advertise   Forum   RSS Feeds   Statistics   Tools
