Hello,
i'm using a Philips 5990/12 with vb6rocod latest firmware and a 320GB usb hdd on a 42" Panasonic Plasma (16:9) via RGB Scart.
Everything works fine so far, except that my tv resolution/aspect ratio switches to the correct format when viewing DivX/movies from the usb drive. It works when i view DVDs, then it switches e.g. from 4:3 to 16:9 fullscreen. But with DivX movies it always stays on 4:3 and if the movie is 16:9 it squeezes the movie > conehead effect.
Before you tell me, that I probably downloaded lots of crappy dvd rips with wrong compression headers ot sth., I tested a lot of different movies, without success. Is there somewhere a Divx testfile which should definitely work?
And in the 5990 settings I set the tv format to 16:9.
What can I do to make it work?
Thanks in advance!!
-blackfrogg
Results 1 to 10 of 10
set it to 4:3 and test.
Use HDMI instead of SCART.
@romi7519: I will try 4:3 ... I think I tested that once...but didnt work...but I will try again.
@jagabo: my plasma doesn't have HDMI =(
Can you manually force the TV to 16:9 after the AVI starts playing?
Yes I can do that...everytime manually....but because my sat receiver does that (as well as dvds automatically) I have to switch back to standard auto mode everytime I want to watch TV (because lots of tv broadcasts come in 4:3). I'm just wondering, why DVDs and SAT receiver are switching automatically, but DivX doesn't.Originally Posted by jagabo
I guess the 5990 isn't set the SCART widescreen signal pin when playing AVI files.
http://en.wikipedia.org/wiki/SCART
Maybe vb6rocod broke this functionality. I found several problems with vb6rocod's hacks and have gone back to standard firmware on my 5990/37. You might try that too.SCART also supports automatic widescreen switching. This is an extension of the functionality of a pin which previously only indicated to the TV set that an external signal should be displayed.
Hm I should test that. Thanks for that tip. I upgraded my player from the first day on.
So....I downgraded the firmware to the latest original from Philips, but aspect ratio still doesn't work.
Switching TV setting to 4:3 in the dvd player menu doesn't work as well.
Any other tips?
Does it work with your 5990 and 16:9 tv???
Mine doesn't have SCART (USA model) so I can't test it.Originally Posted by blackfrogg
Philips 5990 & ext. HD via USB
By Ruut in forum DVD & Blu-ray PlayersReplies: 10Last Post: 27th Dec 2009, 17:07 -
Connecting USB harddrive to Philips DVP-5990/37 player
By DVantrease in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Aug 2009, 20:30 -
wrong aspect ratio
By edong in forum Camcorders (DV/HDV/AVCHD)Replies: 7Last Post: 8th Jan 2007, 19:57 -
Gotec 5990 DVD: USB , karaoke, memory key, divx
By drfritz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Oct 2005, 23:36 -
Wrong aspect ratio
By bri2366 in forum Software PlayingReplies: 2Last Post: 28th Oct 2004, 17:02
