With the info above I managed to compress a 15minute video 11gb in size to 750mb with decent qualitythank you
Results 61 to 72 of 72
More recently, I've bought a Windows 7 Professional machine with 8Gb RAM, with a i7 860 @ 2.80Ghz processor. I'm using the 3.9.1 drivers and I find that while I can get a picture in Blackmagic Media Express (which I couldn't before until I got the resolution setting right), I can't at all in Virtualdub, just a blank screen. I've tried installing other codecs (following what I read in another thread on here), including now the Klite pack 6.6.6, but to no avail.
Even after installing codecs, no other compression options are coming up in any of the menus, so I don't know what's going wrong here. If I select Blackmagic 8-bit MJPEG Codec, Vdub just crashes.
However, if I was to record in Blackmagic and compress in Vdub, I can't find anything that'll give me a CQ3 setting. I might sound a bit thick with this, but can you give me a step by step guide, please? Ta.
If you can tell me how to record in Vdub, please do as I know it's worked before but I've no idea why I'm getting a black screen here. Thanks.Dom Robinson
Editor, http://DVDfever.co.uk
dvdfever are you trying to capture using VDub?
Yep.
Dom Robinson
dvdfever,
You get the CQ3 setting when you edit the settings of the codec you use in Vdub. For instance if you choose divx/xvid you should see a config(ure) option on the right. You should be able to take care of it there.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
As far as I know DVDFEVER the only applications you can use to capture the video from the BlackMagic Intensity pro are the media express software provided and I believe some people have managed to capture video using Adobe Premier.
Hi, I'm very late coming back to this and apologies for that, but while I have had success in recording videos from my Xbox 360 to my newish PC, I tried to use Vdub again and can't find a divx/xvid option in the codec screen, and hence, no CQ3 option.
Even if I use the Blackmagic program for Xbox 360 games, I'd still like to use the 'Screen capture' mode in Vdub to record games played on the PC.
Thanks in advance and I will reply sooner next time
Dom Robinson
Just to be sure you have to have divx or xvid installed in order for vdub to use it.
Depending on which vdub you are using either use video - compression and select it from the list. Or in file - save as at the bottom of the dialog box is the option to change from the default uncompressed rgb option and select divx/xvid from the compression list again.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Dom Robinson
I'm not sure what cq3 is other than "constant quality level 3" I guess. But I don't know which versions of divx and xvid have which features.
Perhaps if you let us know which version of xvid you installed somebody else would be able to help you out.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Dom Robinson
as for the Frames/Sec issue,
I record 720P 60 frames per, and downsameple to WMV-VC1 30 frames per when I encode, you have to make sure the project is set to 60 frames, and edit in 60 frames per then when you change the frames/per.
or in Virtual Dub, Load the AVI and goto , VIDEO, "Convert To | 30 | fps."
I was able to record 720P MJPEG fine on my rig for the last 4 years.Windows 7 Ult.64,MSI K9N Plat. SLi,Athlon64X2 6000+@3.2GHz, 2GB DDR2 XMS2, eVGA GF8800 GTS SSC 640MB, Intensity Pro 10-Bit HDMI Video, Creative XFi Fata1ity Plat.
blackmagic intensity pro xbox 360 help
By tehshame in forum CapturingReplies: 11Last Post: 18th Nov 2010, 14:24 -
Help capturing from Xbox 360 with Blackmagic Intensity Pro
By SkinnyRabbit in forum CapturingReplies: 10Last Post: 1st Oct 2010, 09:44 -
Blackmagic Intensity Pro + Xbox 360 Hookup Question
By xmadmardiganx in forum CapturingReplies: 6Last Post: 15th May 2009, 16:52 -
Best HDMI Splitter for Use with Blackmagic Intensity Pro + Xbox 360?
By xmadmardiganx in forum CapturingReplies: 0Last Post: 22nd Apr 2009, 14:27 -
blackmagic intensity / Xbox 360 / Adobe premiere pro CS 3
By jonakangou in forum CapturingReplies: 11Last Post: 16th Jul 2008, 23:42
