Results 1 to 11 of 11
    Jun 2007
    Kuwait
    hello VH members,
    I'm trying to convert mkv file to avi with the same quality using Xilisoft MKV Converter but i can't. can anyone tell me how to do that with Xilisoft MKV Converter or other program ?
    Regards,
    SB4
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    You may need about double the bitrate and double the filesize or a bit less to keep the same quality, assuming conversion to Divx/Xvid. But it depends on the bitrate/quality of the MKV file.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    To begin with, how is the video encoded ? It may need to be converted if it is H264 video, in which case take note of Redwudz advice, as it is sage indeed. However mkv can be compressed in many different ways. It could be that all it needs is to be repackaged into an AVI container, in which case no re-encoding is necessary.
    Without knowing what is in the box, it is hard to say what you need to do. Although personally, I wouldn't use Xilisoft tools if quality is high on th elist of requirements.
    Read my blog here.
    Jun 2007
    Kuwait
    Ok, how i know the bitrate and quality of the mkv file ?
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Mediainfo would be a good place to start
    Read my blog here.
  6. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    MediaInfo should be able to give you some information about the file.
    EDIT: OK, guns1inger, I'll quit following you around.
    Jun 2007
    Kuwait
    this is mkv file info:
    Video: MPEG4 Video (H264) 704x480 (853:480) 23.98fps [Video]
    Audio: Dolby AC3 48000Hz 6ch [Audio]
    Mar 2008
    India
    Use AutoMKV
    Jun 2007
    Kuwait
    this is the info from MediaInfo:
    General
    Complete name                    : Pocket.Monsters.Movie.11.mkv
    Format                           : Matroska
    File size                        : 1.34 GiB
    Duration                         : 1h 36mn
    Overall bit rate                 : 1 994 Kbps
    Encoded date                     : UTC 2008-12-23 21:53:27
    Writing application              : mkvmerge v2.3.0 ('Freak U') built on Sep  8 2008 18:32:16
    Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L3.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 8 frames
    Muxing mode                      : Container profile=Unknown@3.1
    Codec ID                         : V_MPEG4/ISO/AVC
    Duration                         : 1h 36mn
    Bit rate                         : 1 328 Kbps
    Width                            : 704 pixels
    Height                           : 480 pixels
    Display aspect ratio             : 16/9
    Frame rate                       : 23.976 fps
    Resolution                       : 24 bits
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.164
    Writing library                  : x264 core 60 r934 fd1de69
    Encoding settings                : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=5 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=4 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=crf / crf=18.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
    Audio #1
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Codec ID                         : A_AC3
    Duration                         : 1h 36mn
    Bit rate mode                    : Constant
    Bit rate                         : 384 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Surround: L R, LFE
    Sampling rate                    : 48.0 KHz
    Title                            : 5.1
    Language                         : Japanese
    Audio #2
    Format                           : AC-3
    Format profile                   : Dolby Digital
    Codec ID                         : A_AC3
    Duration                         : 1h 36mn
    Bit rate                         : 192 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : L R
    Title                            : 2.0
    Language                         : Japanese
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    I would use xvid4psp, load the mkv, choose the avi hardware profile, under audio choose copy, convert. You can adjust bitrate if you like under video and click on the e-button.
    Jun 2007
    Kuwait
    i will try
