I'm a newbie at this. Yesterday my friend told me his DVP5960 played avi files thru the USB interface. Is this the most affordable player to have this capability? The 5960 seems hard to come by and I found the DVP5990 more easily available. My questions are:
1. What are the difference between the 5960 and the 5990? Is one better than the other or have advantages over the other? When comparing them on the Philips website, they seem identical.
2. Can the DVP5990 also play avi files?
3. Is the 5990 simply a new the newer version of the 5960?
Any further input on playing avi files to the TV, thru a flash drive would be great.
Results 1 to 17 of 17
5960: USB 1.1 (too slow typical for VOB), max output 1080i, silver.
5990: USB 2.0 (plays VOB), max output 1080p, black.
Note that AVI is a container. It can contain audio and video compressed with any codecs. These are Divx certified players that play Divx/Xvid and MP3/AC3 in AVI. Yes you can play off USB flash drives. The won't play some very high (for Divx) bitrate MPEG4 files.
If you have an HDTV consider the Western Digital TV HD Media Player.
A:
1.The 5990 is 1080p and USB 2.0
2.Yes if they are SD DivX
3.Yes
I have a 5982 and it's USB 1.1 with 1080p,the higher the model number the better it is.What's nice about the Philips players is you can connect an external HDD(FAT 32) to play your DivX and MP3 files.
I can add that the 5990 also plays .wmv, and I believe, but haven't tested, that will also play ogg video stuff.
FWIW, current retail in NZ has it at $NZ150. On special deals this can drop to around $NZ80.
Get one, then get the VB6ROCOD modded firmware and turn a good device into an excellent one!
Cheers!!
Except it doesn't play some files that play perfectly fine with the standard firmware.Originally Posted by Oosername
Thanks to everyone for the great responses. Helps a lot and gives me a better understanding. I want to clarify one more thing. I plan on using this player to play movie files that I download from torrents that I will then load on a thumb drive. I believe most of the popular avi movie files from torrents would work on this player, right?
Most Divx/Xvid AVI will work as long as the resolution is 720x576 or less. Nothing over that resolution will play.
Thank you, again.
How does the WD HD TV Media Player compare to the DVP5990 as far as playing files off thumb drives? Can they both play the same formats? Can one play more formats than the other? If not, it would seem the 5990 offers the same benefits as the WD HDTV Player w/an extra of also playing DVDs and being half the price.Originally Posted by jagabo
Yes, the WD player supports a much wider array of containers and codecs. It also supports high definition playback (the 5990 does not) of Divx, Xvid, MPEG2, and h.264.
http://forum.videohelp.com/topic358929.html
No DVD player though.
jagabo, thanks again.
AFAIK the wd also plays back FLAC format music (ignore this if you dont know about FLAC music).
The WD can read its files from a USB attached hard drive(or thumb drive), which can be in NTFS format, meaning you can have looooonnnnngggg file names AND files over 2gb/4gb, (it will play ISO images, ignore this if you dont know about ISO images).
Long file names can be a real boon especially if you are collecting Tv episodes.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Do you mind me asking which files you mean? I just bought a dvp5990 and installed the new firmware pretty much right away. So far I haven't had any problems playing anything from disc or usb. Just curious.Originally Posted by jagaboCheers,
Wanderlustus
Some random Divx/MP3 AVI files I had. Wouldn't play from USB flash and DVD. Reverted to original firmware and they played just fine.Originally Posted by Wanderlustus
OK Jag', thanks for the reply. Did you ever post some info' on the files in question to see if there was a major difference in them that might have caused this?
Cheers,
Wanderlustus
No, I didn't post the properties of those files. I don't remember which files it was now. I just installed the latest mod (32). If I run across something that doesn't play (and does when reverting the the original firmware) I'll post about it in the 5990/37 mod thread.
Ok, Jag. Just curious and I'll do the same if I come across something. Now that I think of it, I've a few "problem" files that wouldn't play on my LD LGA-730 when it was still working. I should give them a shot and post my results. Thanks for getting back to me.
Cheers,
Wanderlustus
Playing Video Files on DVD Player with USB
By Seachd12 in forum Video ConversionReplies: 5Last Post: 20th Dec 2010, 10:04 -
Usb avi files on dvd player
By KURRDOGG35 in forum Newbie / General discussionsReplies: 1Last Post: 1st Nov 2010, 13:59 -
Connecting USB harddrive to Philips DVP-5990/37 player
By DVantrease in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Aug 2009, 19:30 -
Can I play HD divx files on a NON-BlueRay Player (DVP-5990)?
By DVantrease in forum DVD & Blu-ray PlayersReplies: 17Last Post: 20th Nov 2008, 15:18 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 03:55
