I am yet again having limited read speed with a new internal dvd burner. This exact model.
http://www.newegg.com/Product/Produc...82E16827131059
This is from another thread I made about a LG burner with the same issues.
"I am trying to use DVD Decryptor or DVD shrink to take off the movie files of a DVD. Before, I had an external Phillips DVD burner. It had speeds of about 15x when reading DVD's using either of those programs. Now I have an internal Sony Sata DVD burner.
I can only get read speeds up to about 7x, and it gets to that speed very slow. Nowhere close to as fast as my old Phillips. Nero drivespeed is set to fastest possible(16x according to the drive anyways)"
Pretty much same deal as this thread.
http://forum.videohelp.com/topic360922.html
16x is the max read speed. doesn't mean it will read anywhere near that speed in use. sounds weird but it has to do with limiting read errors, so windows won't force the drive into pio mode. 16x is the peak max and only on a perfect disc. try it on a commercial pressed single sided dvd and see if it gets there.
That's why I kept my old LG as a ripper/reader along with my new LG.Originally Posted by Clint Eastwood
The max readspeed is always lkimited by these combination:
drive (hardware) - firmware - software - medium*** Now that you have read me, do some other things. ***
If this is all true then why does the old Phillips external read at a higher rate? It can get to 11x-15x. This one can't go above 7x.
I've tried downloading firmware updates and the like with the drives. I guess I could try a burned DVD-R movie and see if a drive rips at a higher speed.
I returned the Sony. I'm probably going to go with this Pioneer drive from Newegg. I've heard good things about Pioneer.
http://www.newegg.com/Product/Produc...82E16827129032
Thanks for the help guys!
LG drives have always had RIP LOCK on their read speeds...dunno why they continue that. The PIONEER drives don't have RIP LOCK on their read speeds so it should rip fairly fast at 16x. But if you're talking about commercial dvds that are at least 8gbs then you get rip speeds of 12x. You could use MEDIA CODE SPEED EDIT to enable faster ripping speed with that PIONEER drive.
SONY doesn't even manufacture their own drives. Last I knew they used NEC and or SAMSUNG to manufacture their drives.
Could someone recommend a good SATA CD/DVD burner?
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Feb 2011, 23:41 -
sata dvd burner in older computer
By victoriabears in forum DVD & Blu-ray WritersReplies: 1Last Post: 1st Apr 2010, 01:28 -
Which SATA DVD Burner is best for QUAD System?
By mlong30 in forum DVD & Blu-ray WritersReplies: 20Last Post: 12th Sep 2009, 03:50 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
advice on an SATA dvd burner?
By lumis in forum ComputerReplies: 4Last Post: 19th Jun 2007, 04:09
