VideoHelp.com Forum
  1. Member dynamix1's Avatar
    Good day all,
    I was wondering if anyone has successfully converted any divx files to play on the creative zen. I have looked at their playable formats and every time I convert it the audio is out of sync. Anyone with help on this. Thanx all.
    I reject your reality
    and substitute my own.
    - Adam Savage -
    - Mythbusters -
    I thought the Zen players already supported Divx (the codec). If you have a .DIVX file try just renaming it .AVI. Which Zen are you talking about? There are a zillion models named Zen - something.
  3. Member dynamix1's Avatar
    sorry for not being specific on the zen. It's the 2gb version
    http://us.creative.com/products/prod...=16999&listby=
    - Adam Savage -
    - Mythbusters -
    Ah, I see, Divx requires transcoding to play on that player. I suspect your divx file has VBR MP3 audio and the converter is having problems with it. I don't know enough about Zen players to suggest a direct fix. But open your file with GSpot or MediaInfo to verify the VBR audio. If that is the problem you can try converting the audio to CBR or uncompressed WAV with VirtualDub or AviDemux. Then Creative's transcoding software should be able to handle it.
  5. Member edDV's Avatar
    The zen support master would encourage meditation.
    q:Lam Shenphen Zangpo
    "Seeking happiness in outer things is like leaning on a wobbly chair for stability. It is impossible to achieve because the object we rely on is itself unstable and constantly moving. Consequently, when it wobbles, we wobble. As a result we never feel content and secure."
    http://www.kiva.org/about
  1. Creative Zen TV out...
    By divxmpegjpeg in forum Newbie / General discussions
    Last Post: 5th Feb 2010, 09:43
  2. Creative Zen question
    By marlo in forum Newbie / General discussions
    Last Post: 14th Aug 2008, 16:52
  3. Possible alternative to the Creative Zen?
    By Steppanyaki in forum Portable Video
    Last Post: 24th May 2008, 23:31
  4. Video on the brand new CREATIVE ZEN
    By respekt in forum Portable Video
    Last Post: 28th Dec 2007, 16:08
  5. Replies: 11
    Last Post: 19th May 2007, 04:31
