Can anyone recommend a Solid authoring program other than Encore? I have just started using Encore CS3 and have run into a lot of bugs. I have used Sonic in the past and found it pretty reliable but have not been shopping around for awhile.
It needs to be able to burn DVD and Blu-ray discs.
Thank you!!!
Ulead DVD MovieFactory is OK but may not be flexible enough for you. I don't know how good its Blu-ray authoring is. I've only used it for DVD.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
I've found TMPGEnc Author Works 4 to be rock solid. Haven't tested the Blu-ray
burning because I don't own a BR drive.
http://tmpgenc.pegasys-inc.com/en/product/taw4.html
Recommend best free program / guide for mp3 reencoding?
By Batchman in forum AudioReplies: 5Last Post: 21st Feb 2012, 20:50 -
Can anyone recommend a DVD authoring program that will fulfill my needs?
By smythotech in forum Authoring (DVD)Replies: 5Last Post: 17th Aug 2011, 17:37 -
Recommend video conversion program for older hardware?
By mr-scarface in forum Video ConversionReplies: 1Last Post: 4th Mar 2011, 02:29 -
Recommend a batch conversion program for mkv to wmv?
By yoda313 in forum Video ConversionReplies: 2Last Post: 23rd May 2009, 06:58 -
Can someone recommend a good package for editing/authoring?
By bek in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 16:20
Statistics
Newest guides
Latest tool updates
New media comments
