For some unknown reason when I try to export a movie sequence as a WMV file by using 'Quicktime Conversion' IT ONLY RENDERS THE FIRST 30 SECONDS of the sequence! I have never run across this kind of problem before. Does anyone know how to successfully export from FCP to Windows Media (WMV) ?
I have Final Cut Pro 6.0.5
Thanks in advance!
I went crazy with this problem until I added flip for mac studio pro.
I also added squeeze which is what I use to export to .wmv.
Not sure if you need squeeze.A picture is worth a thousand words, but a good camera is worth about a thousand bucks. -
Does that program allow you to export WMV files DIRECTLY from final cut or does it only convert them AFTER you make a quicktime file?
you just have the free Flip4Mac codec (free to decode) but not the commercial Flip4Mac codec to encode (50$), right?Originally Posted by accumulator
byeSome drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08) -
I ended up buying the Flip4Mac Studio Pro for $99 and it now exports from Final Cut Pro perfectly! Thanks for the info!
Final Cut Pro on Windows?
By HoosierGuy in forum EditingReplies: 2Last Post: 17th Jun 2011, 22:18 -
Export from Final Cut Pro to format editable on PC (eg. AVI) retaining HD
By adrien23 in forum MacReplies: 3Last Post: 31st Mar 2011, 19:45 -
From Vegas to Final Cut Pro - How to export without (much) quality loss
By BovineofWar in forum MacReplies: 18Last Post: 28th Apr 2010, 21:04 -
Final Cut Pro Slow Export
By gooberguy in forum EditingReplies: 1Last Post: 5th Apr 2010, 16:23 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 19:18
