VideoHelp.com Forum
    Hello!Why isit when i insert a Memorex 8.5gb dvd+r dl 2x disc it reads on my pc . But when i insert a Memorex 8.5gb dvd+r dl 8x, my pc just freezes and never reads it.Even blank 8.5gb dvd+r dl 8x.
    Whats the problem??
    I checked device manager. My dvd drive is under 'DVD/CD ROM Drives'. Its all there, and the firmware is updated.
    Any help please.Thank You.
    My devise is Philips spd2413p support 8.5gb dvd+r dl.
  2. Member victoriabears's Avatar
    more detail please.
    The offending dic is a blank one or has something on it?
    Off the top unistall the dvd drive in device manager, just right click it, and uninstall and re-boot.
    May fix problem.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  3. Mod Neophyte Super Moderator redwudz's Avatar
    The burner may not have a burning solution for Memorex DL+ 8X. You would have to find out who makes the Memorex. (Manufacturer)
    From our DVD Media page, it appears to be Ritek/Ricoh:
    http://www.videohelp.com/dvdmedia?dv...+or+List+Media
    And this appears to be a list of media that the drive supports:
    http://club.cdfreaks.com/1767490-post7.html
    But I would just try Verbatim DL + 8X and you might have better luck.
    And welcome to our forums.
    EDIT: All the above references are for burning a DL, not reading it. Sorry to confuse.
  4. DVD Ninja budz's Avatar
    rule of thumb when using DVD+R DUAL LAYER MEDIA is use only VERBATIM. all the other brands will render problems when either burning or reading the disc back.
  1. Taiyo Yuden 8X 8.5GB Dual Layer DVD-R?
    By redwudz in forum Media
    Last Post: 31st May 2011, 01:44
  2. bigger DVD-RW's than 8.5gb??
    By cedarhill in forum Newbie / General discussions
    Last Post: 18th Nov 2008, 14:46
  3. Recommended DVD-R for burning 3.5GB-4GB
    By ha13may in forum Media
    Last Post: 11th Oct 2008, 09:24
  4. Possible movies in a regular DVD (4.5gb)?
    By Rayster in forum Newbie / General discussions
    Last Post: 9th Oct 2008, 10:23
  5. Newbie Help VHS DV (63gb) to Verbatim DVD+R DL (8.5GB)
    By zack28 in forum Newbie / General discussions
    Last Post: 19th Sep 2007, 11:23
