VideoHelp.com Forum
    my 5990 HDMI was working @1080p with my LCD properly for a few weeks. Just now the HDMI connection starting showing a orangish color instead of the original blue/grey color. I tried the following:
    1. the YPbPr connection is normal at 480p
    2. the HDMI cable is normal, I use my computer to connect and it shows all the color normally on the LCD
    3. I tried flashing the firmware again, no luck.
    could it be the problem with the HDMI port on the player itself? any other thing I can try?
    Thanks for the help in advance.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Unfortunately, that may be the problem. There was another post here with the same problem a while back. May be a defect that surfaces with the player on occasion. If the warranty is still in affect, probably trade it in.
    But HDMI negotiation is problematic at times. If your cable and your display works properly, then the 5990 HDMI port may have died.
    Or others may have some ideas.
    And welcome to our forums.
  3. Member victoriabears's Avatar
    Mine did that, unplug it leave for 2-3 minutes-plug it in again
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    with the player on or off?
  5. Member victoriabears's Avatar
    off I suppose, do not think it matters.
    You are resetting it, fixes a lot of common av problems.
    Thanks! it works after unplugging the power cable.
  7. Member victoriabears's Avatar
    Really ! so we do not need hydro anymore
    sorry couldnl;t resist it
  1. USB Problem with Philips DVP 5990
    By bufbt in forum Newbie / General discussions
    Last Post: 5th Jul 2010, 12:52
  2. Can't get Philips 5990 to fill the screen on HDMI
    By ahhaa in forum DVD & Blu-ray Players
    Last Post: 1st Jun 2010, 09:13
  3. Philips DVP 5990/37X HDMI output does not provide sound
    By mani11 in forum DVD & Blu-ray Players
    Last Post: 5th Jan 2010, 15:26
  4. Replies: 9
    Last Post: 11th Mar 2009, 22:50
  5. Phillips DVP-5990 - HDMI problem?
    By Ai Haibara in forum DVD & Blu-ray Players
    Last Post: 3rd Jan 2009, 02:18
