VideoHelp.com Forum
    Hi
    Anyone know if zoomplayer can interfere with Ripbot264? I can see that they both use ffdshow....
    No. WHat is your problem with ripbot264?
    Hi
    Well I'm not really sure... I try to find any error source of the trouble I have. The thing is that I rip a BD movie this way...
    * Use TS muxer to create ts files.
    * Open that ts file in ripbot and create a mkv file using 2-pass with aproximatly 6000Kbps and 4.1 profile
    That conversation works fine and I can watch the movie on the computer without any trouble. But when I watch the same mkv file in my Tvix 6500 I can watch for a certain amount of time then the Tvix reboot. This appears on the exact same position in the mkv file. I have tryed with two different firmware for the Tvix but that does not help. I have also sent the mediainf about the mkv file to Tvix support, but they cannot see anything that could cause any trouble.
    So Im a little lost on what might be causing this weird behaiviour. Any tips on what I can do to find out the error source is greatly appreciated.
  1. Interference from Incandescent heat lamp
    By Bshanahan in forum Capturing
    Last Post: 19th Feb 2010, 14:37
  2. Interference from Firewire??
    By alhenderson in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th Nov 2008, 14:52
  3. Material with interference problems needed
    By sylvanez in forum Restoration
    Last Post: 28th Oct 2007, 14:21
  4. Replies: 4
    Last Post: 13th Jul 2007, 11:39
  5. How to suppress vertical bar interference?
    By Wile_E in forum Restoration
    Last Post: 4th Jul 2007, 16:13
