I have been using VobSub for along time and never experienced a single problem. I was also very delighted by the easy tool SubReSync... The fact is that in the past few months SubReSync won't start. I have the latest version of VobSub and everything seems to be working fine except SubReSync and SubMux.
I can't say much more because they don't crash or anything, they simply won't start at all. But...
Last time I installed WinXP I immediately installed VobSub and the mentioned apps worked... I suspect it's either because I have the DirectVobSub filter installed with K-Lite Mega Codec Pack, or because of certain Windows updates... Does anyone have the same problem or maybe knows how to fix this? I already tried SubRip and realised it sucks because it's very inacurate and tiresome for me.
EDIT - Okay, sorry, found the answer 5 min. after posting this, but I'll keep it up for others that may not know abou this. Appearently, the problem is within IE8 beta... Jus uninstall this and use IE6 or 7 and it'll work just fine.
Results 1 to 24 of 24
Thread: SubReSync problem
Thanks for posting the solution!
Thanks for the post.
I could solve my problem using your help !! :P
best regards.
Hello, dear all.
I'm here to tell you that when I just have uninstalled IE8 (it's updates) and back go to previous version, like 6 or 7, even DVD Shrink (which coudn't be opened properly without crashing since then) just works allright again! :P
In other words: do not use IE 8, because it's have many unstable code, causing errors in many other programs, just DVD Shrink or vobsub, for example.
Wait for stable and very tested (and final) version instead.
Thanks for the advice, Gornot!
Best regards.
Right, I have the same problem. I have IE8 final installed with SP3. Even in the final of IE8 they did not fix this problem.
I would just rollback IE8, but because I have SP3 installed, I can't do this without also rolling back to SP2.
I have some programs with dependencies on the OS being SP3. I would rather not have to rollback to SP2, uninstall IE8 then reinstall SP3.
Is there some other solution this problem or am I going to have to uninstall rollback my service pack too?
Many thanks Gornot for posting the solution - I was in such a muddle over this, just uninstalled IE8 and vobsub is running perfectly!
Cheers,
skip
Great, thank you so much!
Now it's working, just un-installed IE8 and it's updates...
Was on the brink of loosing it altogether...
This is happening to me..but I'm sure I've used subresync since I updated to IE8. Is there anything else causing this problem? I remember using subresync like 2 weeks ago or so..but today I needed it and nada.
I really can't uninstall IE8, so there has got to be another solution to this.
Can you restore the system prior one month ago, maybe? Or install again your Windows system, fixing possible files damage or "corrupted" files.
Try uninstall IE8. Instead, use previous version like 6 or 7.
PS: IE is not good browser in my opinion. Try to use Firefox, Opera, Safari or Chrome.
Best regards.
I actually formatted not that long ago. I know I had IE8 before and seem to recall using Subresync during that time.
I use firefox all the time, but note my location. Korea runs on activex and 99% of in country websites are designed exclusively for IE and will not function in Firefox, so not using IE is not an option.
has no one been able to figure out what it is exactly that is installed with IE8 that makes sub resync fall apart?
Try this fix:
http://css.setti.info/~perplexer/vob...bsub223fix.zip
Should be working alongside IE8 also.
It works, thanks mate!
Thanks Preplexer!
It works very much
Thanks for the post. You are so lovely.Originally Posted by Gornot
best regards.
Originally Posted by Perplexer
Thanks Preplexer!
It works very much
God bless you.
Dear friends
I tried to download this fix ( vobsub223fix.zip ) but nothing there to download , the link didn't work , can any of you post this file here please so I can download it
or at least renewed the link
thank you all inadvance
The server was temporarily unavailable. It should work now.
thank you Perplexer it realy does work fine
Hi,
Can someone please re-up vobsub223fix.zip file for me? I am also having problems using SubResync along with IE8. I tried the link posted and there's nothing there.
Thank you very much.
Thanks a million... works like a charm now. almost tear my hair out trying to figure out what's wrong.
That worked great...
But now a new problem since the latest patches for XP (SP3). Subresync starts, but when I try to do anything I get an error:
any suggestions?Code:MoleBox launcher fatal error Error at <stripped>:48 Reason: ASSERTION failed
Well, I am glad that the solution I accidentally found helped you guys.
Needless to say that VobSub works on Win7 with IE8, so ditch XP and upgrade :P
I am trying to assign .sub to subresync so that I can open the sub file with subresync by double clicking but double clicking only brings up the subresync open dialog.
What am I doing wrong?
xp media center sp2.
Recommend a good subripper besodes Subresync
By Mephesto in forum SubtitleReplies: 2Last Post: 5th Jan 2012, 01:31 -
Only one subtitle on subresync
By derl30 in forum SubtitleReplies: 0Last Post: 25th Oct 2010, 15:55 -
Subresync edit individual subtitle lines?
By Ollielufti in forum SubtitleReplies: 0Last Post: 8th Jul 2010, 09:58 -
Unable to run VobSub (SubResync or Submux)
By DeathStalker77 in forum SubtitleReplies: 1Last Post: 16th Sep 2009, 17:07 -
subresync handling multiple lines of text
By pickleloaf in forum SubtitleReplies: 3Last Post: 2nd Apr 2009, 16:23
