How to write these vb code on loginId and password?
1. When a user had tried to enter the password unsuccessfully for TWO (2) numbers of times, it will display a prompt to ask user whether they want to reset their password or continue?
2. When User selected the option to reset their password, the system will prompt him for a secret questionn. if he answered correctly, then the application will show reset the Old Password and will ask the user to key in a New Password and key in again to Confirm the New Password.
3. If the user does not want to reset his/her password, the application willl only allow ONE more tries?
4. The application will exit the program when the user had keyed in more than THREE (3) unsuccessful logins.
Thanks for helping me to write the code......
Thread: how to write vb code?
Pls help me if u can!!!!Originally Posted by emogal
Coz I am rushing for this project!!!!
...vb code
For what kind of application? Web, stand alone Visual Basic program, database frontend...???
Your question contains to less info for any help.GUI for dvdauthor:
http://www.videohelp.com/~gfd/
Most of ypour questions pertain to general programming, rather thanvideo-related programming, so I suggest that you go here for future questions of this nature. This board is more for video related information (Videohelp.com)Originally Posted by emogal
If this is for school, try to get help from classmates, or read your textbook carefully. If this is for work, you are screwed. You shouldn't take on a job which you are not capable of handling.
yep and if it's a class you shouldn't have been sleeping when the teacher taught you these basic programming concepts.
This nid to be using visual basic application.....
I did pay attention to class and I attending this module doesn't required me to buy textbooks so I dun hav this module textbooks....
My teacher juz teaches me really simple basic of visual basic practical onli
My teacher haven teaches me so difficult code he juz teaches me the simple theory
So pls can me if u can........ I am juz a beginner.........
sony DAV-HDX589W multi code zone code
By sam1821 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th May 2010, 15:37 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37
