VideoHelp.com Forum
Page 5 of 5
FirstFirst ... 3 4 5
Results 121 to 140 of 140
  1. It would be possible (for time/date/timecode etc) but I don't think anything exists to do it.
  2. hmm i see then, however before i go on with that, i would preferably like to capture with Adobe Premiere Pro with Scene detection, but of course it doesnt work for me, do u have any idea why?
  3. hey again, i just came back to start doing as wat u said, but one again i have been getting it crashing again, even adding the .reg to the registry and the error message says error unpacking package or something like that 'E2'.
    sorry about this.
  4. According to MS, you have a missing system file (gdiplus.dll) which is very, very odd. You can get it here:
    http://www.microsoft.com/downloads/d...DisplayLang=en
    Let me know if it works.
  5. i downloaded it, and it extracted to the desktop, thus i got 2 folders there, but yet it didnt make a difference.
  6. Please answer the following:
    1. Can you run the Enosoft DV Processor by itself (i.e., from the Start menu)?
    2. Can you run the clip marker program at all? Does it start up or does it crash?
    3. When exactly does the E2 error happen?
    4. Does your C:\WINDOWS\SYSTEM32 directory contain a file called gdiplus.dll ?
    Do you have access to another PC? Does the software work on it? I have tested it on half a dozen different systems/versions of Windows and haven't this error ever show up.
  7. 1. No
    2. No and crashed
    3. Suprisingly, its not there, however i copied the .dll into the folder and now it works!
    gonna keep u updated on the next thing.
  8. okay, i hadf a quick go at it, and the first thing i have done was to transfer the file to a DV tape using your software only and not with ClipMarker, and i still get the same results, very stuttery, like a struggling video trying to play, nad as if the file was like too much for one or the other to handle
    also, aspect ratio is not corrected during transfer, even though i renamed the files as u said inorder for the software to do it job.
  9. The aspect ratio bit hasn't be finished yet - I've been waiting to see if you can get the software working on your computer.
    To make sure I understand - you have a DV AVI file create by an editing program (Premiere, I assume) and if you send it to tape using the DV processor then you get sturrery results? Where is it sturrery - on the tape or when you recapture? When you record it to tape, how does the tape look if you play it back in the camcorder? How does the DV file that you create from your editor look when you play it on the computer? What frame rate is it? DV only supports 25 or 29.97fps. If you are capturing the file back to your capture, which software are you using to do the capture?
    BTW - having gdiplus.dll missing is a very bad thing. It is a standard Windows system file used for graphics so something must have deleted it.
  10. dont worry, the gdiplus.dll is back in the system folder, i am intitialyl confused why it wasnt there if it is such an important thing, how does my computer run then?
    okay, the DV AVI has been created by using TMPEG Xpress using the DV codec that was recommended here, i forgot the name, and post processing has been done during the process to convert TFF to BFF and plays fine at 50i. Ive done soemthing like this before, and i manage to take the file to a DV tape without problem using Premiere.
    when taking the DV AVI using ur software, both input and out stutters, but differently, as i would already assume playback from input wouldnt look good and its only the output that matters. What i see been transfered back to tape from the PC is identical (i think) to how it looks on the camera.
  11. Can you upload a ~10 sec clip that Xpress creates to a file sharing website somewhere so I can take a look?
    Please confirm, you have taken such a file created by Xpress using the codec you mentioned and used Premiere to export it to and recapture from tape?
  12. will work on the 10 sec clip shortly, and yes i can confirm that i have made a DV AVI file using Xpress (and Virtualdub to change the field order) and took that into Premiere and sucessfully backed it up to tape.
  13. Hello there, so sorry for such the delay, been unexpectedly busy, however i managed to do the 10secs clip sample, of what exactly looks like when it is sent to the DV tape.
    i hope it works: http://www.wikiupload.com/download_page.php?id=116207
  14. hey Johnny! did u see the sample by any chance?
  15. Not yet. The site requires setting up an account which I'm not too keen on. I'll go there again tonight.
  16. hmm that sstrange, im sure u could download it straight, iw ould do it here, but the 10sec clip is far to big.
    any chance by now u managed to watch it either way?
  17. heeey, how is everything?
    maybe u are still having problems trying to watch it? ive made a megaupload upload of the clip here:
    http://www.megaupload.com/?d=I4SCUTGN
    this should make things easier, please let me know if it works and stuff, and also of course if u know wat the problems is.
    hope to hear back very soon!
  18. Hello Jonny, this is Undead Sega here! how are you? long time no hear.
    i am sorry if i didnt continue pursuing this, althugh still interested, i have made a couple posts here and a PM to you with no reply, also at the same time i was very busy at college doing some work, luckily i am in university now, feels like if time passed by so fast.
    anyways, a couple things changed with me, that is, i am no longer running Windows XP, i am operating Windows 7 64bit, would this make any difference to what has been done so far?
    i will not rush into things too fast yet, i would love to hear back from you very soon and hopefuly this wasnt forgotten at all with u.
    all the best and once again, hope to hear from u very soon.
  19. Hello? anyone at all?
    Are you there at all Johnny???
  20. I'm here.
    Circumstances mean that I cannot do any gratis custom work at this time.
    John.
  1. How to Cut & Merge mini 10 part mini series?
    By skorpinok in forum Editing
    Last Post: 8th Oct 2011, 09:41
  2. Replies: 4
    Last Post: 8th Feb 2011, 17:27
  3. Replies: 2
    Last Post: 4th Jun 2009, 14:02
  4. Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
    By SgtRauksauff in forum Newbie / General discussions
    Last Post: 14th Oct 2008, 02:18
  5. Tracking down old AVI container create/extract software
    By lostinlodos in forum Video Conversion
    Last Post: 16th Dec 2007, 03:26
